Custom Intake
Old Jan 8, 2006
Sohc01Lx's Avatar
Sohc01Lx is an unknown quantity at this point
Custom Intake
After reading numerous reviews and threads about intakes I have decided to change out my exisiting intake to a custom one. First of all I am thinking of doing something similar to the AEM v2 design. If anyone has the specs on the v2 please post them. I plan to go with 2.5" off the throttle body as the v2 does then go to the 3" as the seconday. Instead of using a single filter im thinking of a dual airfilter set up. I would use a 3" exhaust Y pipe at the end with 2 filters attatched. My reasoning for this i believe that the the more surface the air has to come the more horespower that can be made by the intake.
If anyone has an input or suggestions I would greatly appreciate it.
When doing this this I will post pics and results.
Old Jan 8, 2006
starstryke's Avatar
starstryke is an unknown quantity at this point
a single filter is the best setup for the d17 as it only sucks in enough air to make a second intake filter useless. What you could do is concentrate on making that intake air temperature colder, that would be more beneficial.
someone please don't close this but since you're new here sohc1lx, try the search button on the forum, it'll answer a ton of questions even if most of the threads have no working pictures, etc.
Old Jan 8, 2006
dariusld's Avatar
dariusld is an unknown quantity at this point
Your engine only needs so much air, two filters sounds like overkill. I like the idea of saving weight over adding horsepower, sounds like you will be adding a little extra weight with all that plumbing. Remember when in doubt, keep it simple.
Old Jan 8, 2006
RHCP0801's Avatar
it wont add all that much horsepower anyway with that setup than the single filter, the single only adds like 2-3hp
Old Jan 8, 2006
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
well, if u do this, your car will feel like a riding lawn mower, 2 filters would kill your low end, that's why normal cai's suck for our d17s, they have too big of a pipe to supply the amount of compression (although very very slight) for the engine to get enough air into the engine. 2 filters? yea, you will hate it.
Old Jan 8, 2006
Sohc01Lx's Avatar
Thanks for the input. I really do appreciate it. I have searched about intakes and this idea itself and came up with nothing. I will stick with my cheap Bomz racing CAI. Thanks
Old Jan 8, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
honestly your cheap bomz intake will provide about the same gains as your typical "name brand" intake. neither of them will prove to be satisfying to your performance needs.
Old Jan 8, 2006
booba5185's Avatar
cai's on d17s kill your low end by not providing enough pressure to the intake as the stock one does (that's why the stock inlet is smaller), but the cai does provide more airflow at higher rpms, so you get an ever-so-slight hp increase in the higher end.
Old Jan 8, 2006
TemjinX2's Avatar
i think stock is best overall. You won't feel the power of the intake till you hit at least 4500rpm. When i had my aem sri i didn't feel any power till i hit 4k rpm at least.
Old Jan 9, 2006
Sohc01Lx's Avatar
Thanks for all the help. I am going to either go with a header or bored tb then? Which ones first?
Old Jan 9, 2006
booba5185's Avatar
niether, save for turbo or swap.
UltraHDGames
Jun 8, 2016 05:16 PM
juicetayne
Sep 30, 2015 11:02 AM
Cam Diaz
Sep 29, 2015 07:17 PM
carid
Sep 28, 2015 10:13 AM
thaler4cuse
Sep 7, 2015 08:25 PM
