I need tires!!!
Old Jan 6, 2006
MBison's Avatar
MBison is just really niceMBison is just really niceMBison is just really niceMBison is just really nice
Exclamation I need tires!!!
Hey guys. I could not believe what I've seen today. When I was washing my car I've noticed both of the rear tires are completely bald. My car has 2" drop on Eibach Sportlines. I also have SPC camber kit all around, and the tires are Yokohama ES100. The tires are 205/40/17 but I'm trying to get 215/45/17. Would u think they would rub against the fender? Anyways, I need to buy new set of tires or at least two. Please let me know if you have some for sale. I need them asap.
Old Jan 6, 2006
K20me's Avatar
Rubbing will depend on your drop (of course) and your alignment. I recently switched from 205/40/17 to 215/40/17 tires. With the proper alignment, I have no rubbing whatsoever, and my car is pretty low.
Old Jan 6, 2006
MBison's Avatar
my front is a bit higher than the rear. should i go with 45s on the front and 40s in the back? also, switching to 215 from 205 wouldnt make any difference would it?
Old Jan 6, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I have 225/45/17's all around with a 1 finger gap all around as well. Not sure how much of a drop that is, since I'm on megan coilovers.
I think my fronts would rub if I still had wheel well plastic covers ... but other than that, I only rub when I corner HARD
Old Jan 6, 2006
K20me's Avatar
I suggest keeping it the same size, unless you don't rotate your tires at all. Having 215's on 17" wheels (I assume your wheels are at least 7" wide) gives the "lips" on your wheels less exposure. With 205's, the lips on my wheels were exposed a lot which was changed drastically by the 215's. Anyway, I'm happy with 215/40's, but its really all on what you want. Check out the "official rim gallery" or whatever thread at the "wheels,tires, brakes" forum.
By the way, Derek hooked it up BIG TIME with my tires. Thanks again.
Old Jan 6, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^ np man. my loss is your gain ... I always try to look out for others
Old Jan 6, 2006
MBison's Avatar
i wish i had a hook up. i need 2 tires for my rear.
Old Jan 6, 2006
Nodnero's Avatar
I can get you Falken ZE512 for 260. Just to clarify, thats for a set of 4.
Old Jan 6, 2006
MBison's Avatar
can u get me only 2? i need the rear replaced really bad (205/40/17).
Old Jan 7, 2006
itskalvin's Avatar
itskalvin will become famous soon enough
i use to have 215/45/17 on my RH c2s, and i was on sportline also. and when i use to take hard turns it would rub in the back. but i think the C2s were 7.5 wide i think? mbison check how much the GTN's are, i forget =D. but i think if i still had them i would go 215/40/17 also. and if you do go that route then you should change all 4 tires cuz it might look werid with the 205/40/17s in the back. hope everyone jocks on your rims meng.... i know i doo!! haha
Old Jan 7, 2006
MBison's Avatar
yea.. the back is lower than the front so i was thinking about getting the same size for the back and 45s for the front. what do u think?
Old Jan 7, 2006
MBison's Avatar
heh.. ive just looked at the wheels again and i doubt i could go with size other than it is rightnow - 205/40/17. the front could do 215/45/17 easily. please let me know guys what u think.
Old Jan 7, 2006
ZapThyCat's Avatar
ZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to behold
I'd probably do that. I have a sedan so the back is lower than the front, with my drop. I also wouldn't mind the extra little bit of gas milage that comes with having 45's instead of 40's in the front. It would make my speedometer ever so accurate.
Aside from the problems you'd get from rotating your tires though, I doubt you'd have any real problems
Old Jan 7, 2006
MBison's Avatar
anyone has (2) 205/40/17 tires for sale?
Old Jan 8, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
http://www.discounttiredirect.com/di...%2FPerformance
order some of those ... Nitto Neogen 205/40/17 only $65 each ... and there's free shipping too.
Old Jan 8, 2006
MBison's Avatar
ok, great. the price is great
Old Jan 8, 2006
itskalvin's Avatar
i would spend 9 dollars more a tire for the FK-451s =D thats my opinion though. i had both the es100s and the FK-451s and i like the FK-451s better
Old Jan 8, 2006
MBison's Avatar
oh.. i've just purchased 2 of the neo gens for the rear already. is fk-451 a quiet and comfortable tire? lemme know kalvin. thanks.
Old Jan 8, 2006
MBison's Avatar
anyways, what does the treadwear number mean? the bigger the better?
Old Jan 8, 2006
TopFuel's Avatar
Ultimate OG Member
TopFuel will become famous soon enough
treadwear the higher the better because it will last longer(280-300 is good) but then again sometimes the high treadwear is a sign that it isnt as grippy as some others (less than 100 can be seen on the yokohama a048s or 32s)
Jeff
Old Jan 8, 2006
MBison's Avatar
Jeff
cool. thanks a lot!
Old Jan 8, 2006
itskalvin's Avatar
it was more of a comfy ride for me then the es100 i think the side walls were harder then the es100s also
twd000
Oct 4, 2015 12:52 PM
SidCivic
Oct 3, 2015 06:00 AM
siliconvalley
Sep 15, 2015 09:48 PM
alaga
25
Aug 13, 2015 04:42 PM
