water bubbling or gurgle sound?
hey everyone, just did a search on this and i found some similar symptoms, but dont think that i have found my problem
symptoms: between 2-3k rpm inside the car you can hear what sounds like water bubbling or somthing gurgling which sounds like its comming from the firewall
counterpoints:
-does not make the same noise outside the car
-does not make the same noise when the front of the car is jacked up( with jackstands of course)
i just did an oil change and still the same problem. its not running hot or doing anything unusual?? its driving me crazy.
anyone have this problem?
counterpoints:
its air bubbles in your heater core. bleed your coolant system, or just take the radiator cap off the car when the car is cold, start the car and top off the coolant. keep doing this with the car running and the air will eventually bubble to the top.
fvckbg
Jul 7, 2015 07:08 PM
hayden55
Jul 2, 2015 06:12 PM
lilrob1213
37
Jun 29, 2015 06:45 PM
brian257
Jun 4, 2015 08:17 PM
