Can fuel pressure be increased on returnless system?
Old Jan 2, 2006
sitinduk's Avatar
sitinduk is an unknown quantity at this point
Can fuel pressure be raised (permanently) on our returnless system? All u would have to do is change/modify the intank regulator, right?
What would be a safe increase?
Using the equations from RC Engineering's site, a 240cc injector could flow 310cc's if fuel pressure was raised form 45psi to ~75psi, but it's probably not a good idea to run that kind of pressure all the time. Would it kill the injectors?
Old Jan 2, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
fuel pressure can only be raised when there is an adjustable fuel pressure regulator in the fuel system. Unfortunetly there is no adjustable fuel pressure regulator available that works on a returnless setup. This is the reason why so many have switched to a return style fuel system.
75 psi seems really high to be running all the time. my fuel system is based at 43 psi but adds 1 psi of fuel for every psi of boost. (boost referencing fpr) so at most i should see 51 psi of fuel while under 8 lbs of boost.
why not go with some RSX-S injectors which are 310cc. These are popular for boosted d17s including mine.
Old Jan 2, 2006
sitinduk's Avatar
Yea, I probably will.
I was just looking at the install/remove diagrams from the Helms manual and thought this might be a cheap mod.
Old Jan 2, 2006
sitinduk's Avatar
Here's some pics
ID:	63373   Click image for larger version
Old Jan 2, 2006
XSRCivic's Avatar
yeah i know that all too well. i've been in and out that tank more than i can count on my hands.. the only thing you can do there is upgrade the fuel pump.. theres really no room for anything else, especially adding more stuff.
lilrob1213
37
Jun 29, 2015 06:45 PM
mrcell24
May 19, 2015 10:02 AM
TaiChi
Dec 17, 2001 09:09 PM
plastikman
Bolt-on Engine Performance
Dec 13, 2001 03:18 PM
MooCoW
Nov 15, 2001 10:58 AM
