Different K20's
Different K20's
Well like i have been saying over and over again i have the dang k20a from a JDM type S... getting tired of defending what i have and so forth and yad yada.. so to recap heres a look at my engine code
as you can see its a k20a but it doesnt have the PRB code like the type R does .. it has a PNA...
now take a look inside the head
for those of you who can understand the pic.. there are 3 lobes on the intake side and 1 on the exhaust side... heres a closer look at the cams on the intake side of mine
people keep saying that it is the civic si which is bull cause the SI has 2 lobes on the intake and 1 on the exhaust.. heres a close look at what the intake came look like on the si
k... now thats out of the way.. bet you are thinking.. what gives.. there is no such thing as a jdm type s... well.. if i can find the japan site again i for sure can show you on there site that is shows a jdm type r and a jdm type s.. but this will have to do for now
if you read the IVTEC section.. look for my setup which is"3 intake and 1 exhaust"... then scroll all the way across to the left to see what type of motor it is.....
Originally Posted by DaddyFatSacks
Soudnt the engine you have out of a JDM S have 3 intake lobes and 3 exhaust lobes? You have more of an economy head witout true VTEC.
Originally Posted by whitevic
The JDM Type S, is our Base RSX. So, in short, no, he shouldn't have 3 on both sides.
Originally Posted by Spoolin
so basically you might as well have got a k20a3 and had the same hp?
all Japanese motors don't have a number after the letter. Hence, all K20A-series motors are stamped "K20A". it does not mean you have a type R block, it does not mean you have 11.5:1 compression.
JDM Integra GSR engine block code is B18C. NOT B18C1. The JDM DC2 Integra Type R engine block code is also B18C. NOT B18C5.
because the B18C-GSR has the same code as the B18C-R does not make the GSR a Type R. Same goes with the JDM 160 ps type S motor having the same engine code as the JDM 220 ps type R motor.
In fact, if you look at the specs on the Honda Japan website, you will see that your compression is in fact, not 11.5:1, but 9.8:1 ... noted here
Some of you don't seem to understand that there is NO "BASE" RSX in Japan. The BASE model "Integra" (RSX) is called the Type S. The Japanese Integra Type S is NOT a special edition version of the Integra, but is their base/standard model. They only have Type S and Type R. USDM has Base and Type S.
Essentially, his motor is technically not a motor found in the US. it is the same as a normal base RSX K20A3, except it has 3 lobes on the intake cam. His block is most likely the same as a K20A3.
Originally Posted by Kyle23
u have the same TQ numbers as the Si but at 4k instead of 6k. nice....
haha... i see someone found the japan site for me.. lol.. but what i dont get is that when the shop did the voulme test with the block before i put it in my car, they determined that the compression was somewhere between the 11 - 11.5 range
who knows. If they did the compression tests before actually running the motor, it might've have been clogged with carbon ... perhaps the need to start the motor and blow it all out could've been good, if that wasn't already the case.
when I first started up my engine, it was clogged as ****. Took a solid 2-3 minutes of cranking to get it to start up ... first start up was HELLA slow too. You could hear the individual explosions, placed about 1/2 second apart for like 3-4 seconds before speeding up to a 1700 rpm cold-start idle. Not to mention the gunked up ****-smoke filled the entire shop full of nice white/gray smoke.
cliff notes: carbon build up = higher compression readings (which u should already know)
If you do a simple compression test, I'm sure you'll be able to tell by the numbers. I would like to do one on my motor myself.
Once boosted now i-VTEC
Its good to know there are some people around with brains in there heads not rice.
I just burnt my tongue
if you want the japanese site the JDM integra Type-S here is the link
http://www.honda.co.jp/auto-lineup/integra/
you can rep me now or later hehehe
do you still have the data?
Originally Posted by varner88
when i first saw this motor a year ago i was confused and wondered why it was a k20a but then i realized it was from the jdm type-s and yes the compression on them are 11.5 or very close to that they sell this motor on plan B for 2800 bux full swap with 6 speed tranny and everything that u.s type s has except 160hp instead of 200hp
there is no need for that high of compression on that motor
the compression on the jdm type s is 9.8:1. read again.
^ not sure what to tell you. It's not anywhere in the 11's as far as compression goes.
There's no way Honda would rate the K20A - JDM Type S at 160ps if the compression was 11.5:1 AND there is 3 lobe vtec on one of the cams.
11.5:1 would give a pretty decent bump in hp, as well as the 3 lobe. Honda would've rated it at 165-170hp if the compression was that high.
Frankly, I don't see why USDM Base RSX's are still rated at 160 HP since they don't have 3 lobe vtec on the intake ... as far as I know. They should be rated at 155 HP or so.
then explain this to me..
why is it that the base rsx and civic si have
9.8:1 compression
2 intake lobes and
1 exhaust lobe
puts out what about 160hp
then why is it that the jdm type s is
9.8:1 compression
has real vtec on the intake side of 3 intake lobes
1 exhaust lobe
and puts out the same hp of 160...
so the jdm type s has real vtec on the intake side yet has the same hp as the USDM... why waste all that money????
