Giggity Giggity Giggity Goo
Old Dec 16, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
heh heh, alllllll riiiiiight
Old Dec 16, 2005
eye_see_you's Avatar
let the devil out
hmm a blow box!
Old Dec 16, 2005
HonCivX02's Avatar
HonCivX02 is an unknown quantity at this point
nice
Old Dec 16, 2005
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Damn Son...........Thats just sexy.
Old Dec 16, 2005
dezod's Avatar
7thgen Power Maker
OPEN IT UP AND SNUGGLE WITH IT ALREADY. WTH ARE YOU WAITING FOR?
Old Dec 16, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
This is a very nice box! Too bad its emty!
Old Dec 16, 2005
Jap-Euro Fusion
Old Dec 16, 2005
tuner04civic's Avatar
spell check pwns you
**jaw drops** very nice, good luck
Old Dec 16, 2005
civic01vtec's Avatar
I thought you were going externally gated ????
Old Dec 16, 2005
Jap-Euro Fusion
Nope... it was internal all along.
Keep It Simple Stupid rules are in effect.
Old Dec 16, 2005
ramcosca's Avatar
Words on a User Title
Sweet~ Hope you enjoy it!
One of my favorite quotes: "Hello, 911? It's Quagmire. Yeah, it's caught in the window this time."
Old Dec 16, 2005
let the devil out
look almost like my garrett.. snuggles
Old Dec 16, 2005
dezod's Avatar
7thgen Power Maker
Where did you get it from? GT28?
Old Dec 16, 2005
Jap-Euro Fusion
Its a 28R
I got it from Kinetic Motorsports
Old Dec 16, 2005
C Orndorff's Avatar
Once boosted now i-VTEC
C Orndorff is an unknown quantity at this point
Nice
Old Dec 16, 2005
vietstylez's Avatar
haha.. friggin quagmire
Old Dec 16, 2005
civicskater's Avatar
Chicks dig my scent
great choice on the turbo! enjoy
Old Dec 16, 2005
skipbarber's Avatar
boiler, i think you are going to pwn me and my setup.
Old Dec 16, 2005
Jap-Euro Fusion
Well I've had it for about 4 hours and already I'm fishing for more crap. The compressor inlet is 60mm (2 3/8") I can't seem to find a 2.5" to 2.375" reducer, if anyone knows where I can find one of those silicone rings that goes inside the silicone couplers so you can change diameters, I need one. I don't really want to go up to 70mm (2 3/4") for the intake pipe and then have a 2" turbo outlet pipe.
The other viable option is go to a 2" pipe and expand it to the opening, but I don't want to restrict the inlet if I can avoid it.
The turbo also needs to be clocked and I need a new WG bracket.
Old Dec 16, 2005
ImportRacer2123's Avatar
K20 Member
LOL yeah that was GREAT i remember that!
Old Dec 16, 2005
tfnaaf's Avatar
BLDNPSI Mod
odd, mine was 2.5" inlet
Old Dec 16, 2005
You could get a 2.5 to a 2.25 and force it on.
Why do you need a new bracket for the wastegate actuator ?
Old Dec 16, 2005
Jap-Euro Fusion
It will only work in the orientation that the turbo came in. Which is with the turbine inlet vertical and the compressor outlet pointed up. If I was putting this on an SR20, I'd be golden. But I need the turbine inlet pointing horizontal and the compressor outlet pointing down, so it needs to be clocked, once those holes get misaligned, I need a new WG bracket.
Once I find a wrench that's thin enough that I can get in there and loosen all the bolts to clock it I'll be in better shape to see whats going on with the bracket location. A standard 1/2" wrench is too big to get in there, I either need to find a thin headed one, or take a grinder to the one I have.
Old Dec 16, 2005
Logan3024's Avatar
I was able to install my gt28r without relocating the wastegate
Old Dec 16, 2005
Logan3024's Avatar
Oh yea, you better have a oil restricter oil the oil feed.
Old Dec 16, 2005
Jap-Euro Fusion
I have all necessary fittings and hardware to pull it off.
Old Dec 16, 2005
C2i0v0i1C's Avatar
SuperMODrizd
pretty
Old Dec 17, 2005
I see, well you can prolly fab one up. As far as getting a thin wrench, i had to rotate my housing too.......while it was installed in the car. I took a old wrench and hit it with the grinder.
Old Dec 17, 2005
mrDFWmechanic's Avatar
lookin good
Old Dec 17, 2005
Jap-Euro Fusion
Problem solved.... I ground a socket down and got it in there.
