Giggity Giggity Giggity Goo
Old Dec 17, 2005
  #31
Black03civic's Avatar
sweet very sweet
Old Dec 17, 2005
  #32
04|5spdCivic's Avatar
Wish I had a Turbo 3)
04|5spdCivic can only hope to improve
im lovin it. i want a video!!! lol you should make us vid clip or somthing. more pics at least.
Old Dec 17, 2005
  #33
Boilermaker1's Avatar
Jap-Euro Fusion
What do you want a video of? The turbo sitting on my living room floor?
I'm still short on all the parts to install it. Its going to be march or april before its in the car and ready to go.
Old Dec 17, 2005
  #34
GLi4dr's Avatar
GLi4dr is an unknown quantity at this point
So, Im guessing im stoopid here...but is the turbo an SR20 upgrade, or is it just a T28rs to your specs to work with the d17??
Just that you mentioned that if it was to go onto an SR20 youd have no probs, but because its not, you have to play around with it a little. Or is the housing itself made for that and you have diff specs??
ie. can I use an SR20 turbo on the vic??
Old Dec 17, 2005
  #35
Jap-Euro Fusion
Its a universal application turbo. But in the orientation its shipped w/ the WG attached (vertical turbine inlet, upward pointing comp. outlet) its much more favorable to a RWD style setup than a FWD setup. I've seen quite a few SR20s rigged up with turbo ports in this orientation. Its an analogy, not to be literally taken.
And its not the Disco Potato.
Its the plain old GT28R (not the RS)
Old Dec 17, 2005
  #36
dre2600's Avatar
Mmm...disco potato...
Old Dec 17, 2005
  #37
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
french fries...yumm
Old Dec 17, 2005
  #38
Its going to be very tennative video, you should post on streetfire
Old Dec 17, 2005
  #39
GLi4dr's Avatar
lol, yeah, soz, my bad...was half asleep when I posted.
Still, nice turbo and I wish you best of luck getting things just how you want
Old Dec 17, 2005
  #40
tfnaaf's Avatar
BLDNPSI Mod
NOTHING plain about the GT28R !
Old Dec 17, 2005
  #41
Jap-Euro Fusion
It has 2 inlets and 2 outlets... just like every other turbo. Its plain
Old Dec 17, 2005
  #42
tfnaaf's Avatar
BLDNPSI Mod
Actually its 3 inlets 3 outlets....... AIR, OIL, and WATER! But calling a GT28R plain is like calling Jessica Simpson intelligent
Old Dec 18, 2005
  #43
Jap-Euro Fusion
Then it has FOUR if you wanna get that picky
Exhaust, Intake, Oil and Water
Old Dec 18, 2005
  #44
XxJDMCivicxX's Avatar
Well I've had it for about 4 hours and already I'm fishing for more crap. The compressor inlet is 60mm (2 3/8") I can't seem to find a 2.5" to 2.375" reducer, if anyone knows where I can find one of those silicone rings that goes inside the silicone couplers so you can change diameters, I need one. I don't really want to go up to 70mm (2 3/4") for the intake pipe and then have a 2" turbo outlet pipe.
The other viable option is go to a 2" pipe and expand it to the opening, but I don't want to restrict the inlet if I can avoid it.
The turbo also needs to be clocked and I need a new WG bracket.
Didn't read the third page to see if you found a reducer but they atpturbo makes some if not a guy off honda-tech sells them i'll get his username.
Here's the link to all the sizes I know it i'll help out some of your with those tight spaces. They have the size your looking for as well as many others from 4" down.
http://www.atpturbo.com/Merchant2/me...y_Code=SIL-TRN
Old Dec 19, 2005
  #45
Jap-Euro Fusion
Giggity
This is going off to Jet-Hot next week after fedex sorts out the disasters this week.
Intercooler has also been ordered.
Old Dec 19, 2005
  #46
Goes exactly with my line of thought.
You can't go wrong on this one!
Old Dec 19, 2005
  #47
greenEX's Avatar
greenEX will become famous soon enoughgreenEX will become famous soon enough
jet hott
where exactly are you going to send it to get jet hott coated?
Old Dec 19, 2005
  #48
Jap-Euro Fusion
To jet-hot.
The only people who do jet-hot coatings.
Old Dec 19, 2005
  #49
greenEX's Avatar
ok, ok
I just wanted to know the location.
Old Dec 19, 2005
  #50
mrDFWmechanic's Avatar
your rackin up some nice parts
Old Dec 19, 2005
  #51
tfnaaf's Avatar
BLDNPSI Mod
http://www.jet-hot.com/
We are easy to reach via phone or internet.
For Technical Information:
CALL 1-610-277-5646
To Place an Order:
CALL 1-800-432-3379
Old Dec 19, 2005
  #52
Jap-Euro Fusion
Its in mississippi somewhere. They also have other offices but the place you send parts to is in MS.
Request a quote online (its $95 for 4 banger headers and manifolds) they send a packing slip, you send it to them, they coat it and send it back.
Old Dec 19, 2005
  #53
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
thats the best box anyone could get in the mail!
Old Dec 22, 2005
  #54
Jap-Euro Fusion
I'm stitting here staring at 200 F'ing dollars worth of hoses and **** (and I already have 90% of the stuff to make oil lines). Dammit I hate buying AN plumbing (yet its so reliable and looks soooooo cool).
If anyone has any -6 stuff lying around in quantity, I'm looking for it, and I need a bunch of -10 hose ends, and 1 -4 90deg. fitting.
Old Dec 22, 2005
  #55
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
which coating are you getting?
Old Dec 22, 2005
  #56
Jap-Euro Fusion
Sterling 1300
Old Dec 23, 2005
  #57
Jap-Euro Fusion
Turbo is assembled finally...
Here's my pimp divorced port exhaust flange
The new WG that fits is on
And plumbed up (need clamps)
Old Dec 23, 2005
  #58
White0nGold's Avatar
White0nGold has a spectacular aura aboutWhite0nGold has a spectacular aura about
Originally Posted by 03-Acura-1.7-EL
This is a very nice box! Too bad its emty!
owned
Old Dec 24, 2005
  #59
speedster's Avatar
speedster is an unknown quantity at this point
How much power will you hope to get with this setup when your through?
Old Dec 24, 2005
  #60
tfnaaf's Avatar
BLDNPSI Mod
Im running same basic setup as boiler but with an auto trans so he should easily be able to get 170+ hp 150+tq
