Road Noise!!!!!!
this has been an atl01 production..
Road Noise!!!!!!
Hello all, i need some help i am having a LOT of road noise comeing from my car. It almost sounds like im driving in a jacked up truck. The noise is allways there unless i take a sharp left hand turn then it quits but as soon as the wheels stragintn up the it gets loud again. I have put new suspension all the way around and i have put new tires too. I also got a alligment done and it is still makeing the noise and i cant stand it any longer. Any suggestions.
^^^^hey thats a good idea. dynomat is kinda of expensive though. It might help but it wont fix the problem, Im thinking it might be a wheel bering.
what kind of tires do you have? and how are the road conditions where you are? i had some cheapo pepboys tires on for a few months and they were a biatch, then i switched to falken ziex 512s and OMG!
Dynamating the car helps a little but not enough. I know. I have Dynamat Extreme (the aluminum looking ones) on the whole floor, doors, and trunk and it doen't help that much. Most of the road noise gets transmitted up the hollow pillars and gets amplified into the roof area. I'm begining to think the most effective way of reducing road noise is to get a few cans of those spray polyurethane liquid insulation from the hardware store and fill the hollows of all the pillars (especially the A-pillar). Insulate the roof interior panel with more foam or carpet liner. There is a lot of noise transmitted through the thin window glass also. There is nothing you can do about this short of replacing all the glass.
Originally Posted by streetglower
you need to be more specific. telling us there is lots of road noise doesnt tell us anything. Where is it coming from?
I really am starting to lean towards a wheel bearing, but can you replace the wheel bearing in the back or do i have to replace the entier Knuckle??
most road noise comes from the tires. I switched to bridgestone turanza and noise went way down. also alot comes from doors and the floor panels. I ripped out my old carpet and it got loud again. If you don't care about adding weight, then dynamat is a good idea for the doors and floors at least.
the most likely cause sounds like a wheel bearing, you say when you turn to the left. This unloads the left hand wheel bearing and, MAY be the cause of the noise. Could also be a tire that has severe cupping, but more likley a bearing. Its not normal for there to be a noise that goes away when transfering the weight of the car as you describe. Sound deadener will cover up the noise but thats like putting a band-aide on a brain tumor!
Thanks for all yalls help. I think i will start with checking the wheel bearing. How do i check them? My friend said to jack the car and if you can move the wheel then its the bearing, is this the same way to check the back? Is there even a bearing that i can replace in the back, because i dont think there is, i think i have to replace the entire knuckle by looking on this website. www.hondaautomotiveparts.com yall look and tell me what you think.
Hey guys just to update you on what the problem was. It was the passanger side rear wheel bearing had completatly come apart and was causing the loud roaring noise. The part # from honda is 42200-S5A-A21 and it is $54.00. It only took about 45 min for me to put it on it is very simple just take off the wheel, then take off the brake durm, then remove the gold dust cover off the nut and you will see the 32mm nut. You will probably have go buy this size socket because it is pretty big. I just rented it from a local parts store. Remove the nut and the hub assembly slides off and the new one slides on. Mine was a little hard to get off but just beat the hell out of it and it will come off. Hope this help with anyone eles who is having this problem.
15EXCoupe
Jul 30, 2015 12:59 PM
mokkush
Jul 14, 2015 04:05 PM
06Si_Girl
Jul 12, 2015 12:08 PM
