Strange problem...
Old Nov 27, 2005
VietScouty's Avatar
VietScouty is an unknown quantity at this point
Unhappy Strange problem...
For some reason, whenever I turn on my head lights, the right headlight goes out and the rear right turn signal stays on (I mean it doesn't blink. It just stays on) I tried to mess with the signal and it doesn't do anything other than stay on, plus, the AC stops working. If I turn off the headlights and put on my hazards (Turn signals does not blink simultaneously, like it suppose to), the vacuum gauge reads below 20, it used to stay around 22 or 23. I've check every fuse there is on my car and it seems fine, no broken circuts or anything. Does anyone know what the problem is? Thanks.
Turn on headlights - Right headlight goes out, rear turn signal remains on, AC/heater does not work, and vacuum meter drops.
Turn on parking lights - Both signals work, AC/heater unit works, and using any turn signal, vacuum meter drops.
Off headlights - When idling, turn on hazard lights, vacuum gauge changes from 22 to 17. When using any turn signals, vacuum meter drops.
Old Nov 27, 2005
seems like multiple problems. first being a bad combination switch. are you blowing fuses?
Old Nov 28, 2005
VietScouty's Avatar
Unhappy
I've checked every fuse there is on the car. Even the ones below the cockpit. The problem still persist. Any recommendations?
Old Nov 28, 2005
have you replaced the combo switch? the one that turns on headlights. there was a recall for melting wires that caused headlights to burn out.
Old Nov 28, 2005
mugenman's Avatar
"mmmBAHHHH" - vtec y0
grab an ohm meter and start checking grounds. it sounds like a loose ground wire. but thats just me. i know when i was having crazy problems thats what it turned out to be
Old Nov 28, 2005
CraigW's Avatar
I agree, it sounds like a poor ground. I would overlook any work done to the car also. I have some wiring info if you want it PM with E-Mail address.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
Fudman
Suspension
Feb 1, 2020 04:13 PM
i drive
Sep 14, 2015 01:56 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
JJ291
Sep 2, 2015 11:49 PM
