V-AFC II Problem
Old Nov 11, 2005
Hoosier282's Avatar
Hoosier282 is an unknown quantity at this point
V-AFC II Problem
Okay I installed the controller, which was no problem. Every time I go to change the VTEC settings, fuel cut occurs at 4,000 rpm and the check engine light comes on and says something is wrong with the air/fuel meter. (Dont remember the exact code) The input/output and VTEC is at 6, 6 and 3. Does anyone have any idea how I can solve this so I can start changing the VTEC settings without having to deal with fuel cut?
Old Nov 11, 2005
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
well the problem with this is that if you dont change the fuel and air settings ur either gonna run too rich or too lean. I would have this dynoed and have some one do this for you. I tried it the same way you are and the car lugged anytime VTEC engaged. I would just leave it alone till you can get it dynoed. You can really mess up your engine by messing with this.
Old Nov 11, 2005
Hoosier282's Avatar
I've already done that. I had it dyno'd the day after I installed it, thinking that a tune would fix the CEL. During my 2nd pull, the CEL came on and w/out a scanner at the time, the guy said that he couldn't do anything with it. Then he reset the ECU, tweaked it a little more and finally got it to work right. On my way home from the dyno, it hit fuel cut at 4k again and the CEL came back on. Could this problem be installation related? Maybe the VTEC solenoid wire is backwards?
Edit* the Dyno showed that I'm running a good a/f mixture... not lean at all, maybe even a bit rich in spots.
Old Nov 11, 2005
hook up the vtm wire. the apex diagram is wrong for our cars.
Old Nov 11, 2005
Hoosier282's Avatar
Where exactly do you find the find the correct write-up or directions? I know the VTM wire is the blue wire, but what wire does it hook to on the ECU? Also what does VTM stand for?
Old Nov 11, 2005
its the vtec wire. there is a huge thread we made about this.
http://www.7thgencivic.com/forums/sh...d.php?t=169767
Here are the pics since they got erased from the other thread.
Old Nov 11, 2005
Hoosier282's Avatar
Thanks man, appreciate the help, I'll see if it helps me out.
Old Nov 11, 2005
i'm sure it will. just reset the ecu by pulling the fuse or battery to clear the engine light once you rewire (well you need to anyway if you're hooking up live wires).
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
