I read the sticky - srs light on after battery change
Old Nov 6, 2005
StealthCivic's Avatar
StealthCivic is an unknown quantity at this point
I swapped in a new battery when mine went dead after 3 years...now my SRS light is on constantly..........???? what's up
Old Nov 6, 2005
I reset the ecu....srs light is still on...this is the first time this happened, and is ironically the same time as my battery is replaced! 86,000 miles! arrrghhh!
Old Nov 6, 2005
maybe there is actually something wrong with srs. i've pulled the battery more times than i can remember, and the light has never been on. i think if you jump-start the car it could come on.
Old Nov 6, 2005
tfnaaf's Avatar
BLDNPSI Mod
I would agree with ^^^^^ sounds unrelated. But anything is possible
Old Nov 6, 2005
I went by autozone and we hooked up the obdII to check ....no errors at all...so is my srs ok? I will just reset the light, last resort is to go to honda...guy at autozone said the srs fuse might be blown after putting in the new battery
Old Nov 6, 2005
checked all fuses
I checked the fuses for the srs and they are all ok....guess next step is honda...unfortunately........
Old Nov 6, 2005
tfnaaf's Avatar
BLDNPSI Mod
here is the test procedure, i recommend using the honda specified tool. BUT i know it can be done with a jumper wire
ID:	61912   Click image for larger version
ID:	61913   Click image for larger version
Old Nov 6, 2005
tfnaaf's Avatar
BLDNPSI Mod
if you need a larger image let me know and ill e-mail them to ya
Old Nov 6, 2005
thanks bro!!! I just did what you said with the DIY I found searching to reset the srs...it worked!!! And, I used a paperclip, had to do it a few times since I didn't have the honda little accessory, the srs light is off, I just hope there was nothing really wrong with my airbag system - the diy says if you problem is fixed then the light will reset, so I am thinkin my srs airbag system should work fine if I get in a bad wreck, I just don't know why it came on to begin with!!! All I did is replace my dead battery a few days ago. Thanks tfnaaf!!!! I apreciate it bro and thanks for DIY whoever did it!!!!!!! 7th gen has saved me countless $$$$ and keeps me from the shady honda dealer......
Old Nov 6, 2005
tfnaaf's Avatar
BLDNPSI Mod
np at all, rep is always appreciated
Old Nov 6, 2005
you got it man...
Old Nov 7, 2005
the srs light is back on now!!!!!!!!!! arrrgggghhh! What is up?
Old Nov 8, 2005
southpasdena's Avatar
Super Member
southpasdena is an unknown quantity at this point
If it is back on, you got problems with you system. The light will only stay off if everything is A OK with your airbag system
Old Nov 8, 2005
tfnaaf's Avatar
BLDNPSI Mod
That sucks!
Old Nov 8, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
I BET THE PROB IS SEATBELT!!!!!!
mine came on because of the ?chip? in the seatbelt....
Old Nov 8, 2005
thanks ya'll
Yep, I finally broke down and went to honda ready to shell out $40.00. I had been to autozone and used the obd2 but that only reads check engine light not srs, so I finally went to honda to pay. we hooked it up with hondas computer , and sure enough problem diagnosis with drivers side seat belt just like you said. So, he turned the srs light off, but said you have a problem, you can fix it, buy the part, take the seat out and fix it. He went to check and found out it is covered under warranty for my car- safety warrranty!!! yea!!! I don't have to pay for anything at all - all covered, and a dangerous problem will be fixed. So thanks to you all. The honda tech said it was not a good idea to disable the srs in the fuse box like I did. But the computer still picked up the problem with the history. So, I am very thankful , the light is off, and I am getting the problem fixed under warranty, and you were exactly right, it is the seat belt driver side.
Old Nov 8, 2005
shroomster's Avatar
JASON FOR THE WIN!!!!
rep is always nice!
BootyDo
May 7, 2015 04:46 PM
WLakers
May 4, 2015 06:23 PM
bo_red
Transmission
May 3, 2015 09:14 PM
tylerginevan
Apr 27, 2015 12:29 PM
twtron
Apr 17, 2015 12:09 AM
