will an AN8 size hose fit on the oil return neck of my t25 from tsi???? ASAP HELP
hey i got a turbo kit with some stuff missing, im getting the oil feed taken care of, but the return, i found a an8 high pressure hose and i need to know if that will fit onto the neck at the bottom of the turbo, the neck seems to be like..... 5/8ths of an inch wide. ive got no clue how big an8 or 10 or w/e is. i need to know asap so i can get this dam turbo done and on my car.
DONT PANIC
go buy some gates greenstripe that fits the oil return fitting. Then use some band clamps.
Make sure it is fuel line and not coolant line. If you use anything but fuel line or multi-fuel line, it will crack and leak over time.
That should tide you over.
depending on clearances you may want to look in to stainless braided hose, If your doing it the more how shall i say it.....um........ better way, i would use AN fittings As i recall its 1/2" pipe to an-8 adapter, an-8 swivel straight hose end, about 1' of an-8 braided line( will be more then long enougha nd will need to be trimed), another an-8 swivel straight hose end ( possibley a 45 degree depending on oil pan drain location) . Then depending on how you are tapping in to your oil pan , i used a 45 degree steel an-8 fittings and welded it to the pan. see pics links below, sorry bu i didnt get any pics with the line installed.
http://myweb.cableone.net/tfnaaf/images/DSC00188.JPG
http://myweb.cableone.net/tfnaaf/images/DSC00189.JPG
Originally Posted by turboengnr
i was just posting the "cheap and easy getting my damn car to run because i dont wanna f*ck with it anymore and i want to be boosted" method.
RIPSAW
Nov 6, 2015 04:36 AM
Touge
Ottawa
May 23, 2015 05:39 AM
Touge
Touge
May 20, 2015 10:53 PM
Touge
Apr 26, 2015 11:58 PM
