Dyno Results
Old Oct 21, 2005
andyman97's Avatar
Turbo Guru
Dyno Results
Ok, so I finally am getting tuned with the aem. I am at the dyno shop right now. Having some small problems with the plugs in the top end....we're working on it. Best pass this far has been 193.9 whp at 6 psi. Anything over 200 is the goal....and we'll meet that easily. Plus, it's kinda warm outside, it's 82 degrees out, so, we'll see what happens. I'll post up a graph when we finish.
If you want to make power....GET THE AEM, it is seriously awesome.
Oh, btw, I have a completely stock motor with a t3/t4 turbo and d16y8 intake manifold...
Old Oct 21, 2005
HyaBoosta's Avatar
good luck on breaking the 200whp. im right behind you guys with the y8 IM and aem. gonna switch over after I saw you two's results. Andy can you snap me some pics of your IM set up. Especially the throttle cable. It would be a big help!
Old Oct 21, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
aww crap, im sorry dude. I forgot about that pic. Andy thats awesome dude. Just wondering what kinda probs you are having with the plugs?? They put NGKs in mine. I think they used No. 7s. Make sure the alternator is charging, my car got dynoed with the alternator shut off lol. I almost didnt get home from NH because I didnt bring a laptop. Those guys musta not have noticed. Told you the AEM was the ****, hehe. Keep us updated and if you have any questions dont be afraid to call.
Old Oct 21, 2005
andyman97's Avatar
Turbo Guru
Hey thanks, Gery. Yeah, it's just not consistant in the top end. Two of my coil packs were burned out last night so we picked some up that looked like they might have been off of a k series. I swapped them out for d17 ones but we haven't made another pass just yet, so we'll see how it goes. I'm also using #7's.
Hiya-sorry, this is the best pic I have. I just used a stock d16 throttle cable in place of the d17 one.
Old Oct 21, 2005
mrDFWmechanic's Avatar
man can you do a diy about the d16y8 manifold install cause i'm seeing alot more people with it and i already have the manifold just i dont have a clue how to wire and install everything
Old Oct 21, 2005
dezod's Avatar
7thgen Power Maker
Go andy!!!!
Old Oct 21, 2005
02fpcivic's Avatar
Hya, I just pmed you a pic of mine but im not sure if it worked, let me know If it didnt go through. Andy its probably something stupid, you guys will figure it out.
Old Oct 21, 2005
andyman97's Avatar
Turbo Guru
Yeah man, I'm almost postiive it's that stupid alternator cut off. I warned him about it but I think he just kinda brushed me off...we'll see what happens.
Old Oct 21, 2005
02fpcivic's Avatar
yeah andy my #7 output is unchecked where it says active and all the stuff is gray so you cant change it. So what we talked about on the phone was in fact correct.
Old Oct 21, 2005
HyaBoosta's Avatar
thanks for the pic andy & 02fp. andy your using the y8 TB right?
Old Oct 21, 2005
02fpcivic's Avatar
andy is, I am not
Old Oct 21, 2005
ncirom2003's Avatar
i thought you were going with the e-manage ultimate andy, too many problems??? either way :tup for having an ems dude!!!
do you think that manifold would really make a difference on a boosted civic? (what if the head was portNpolished?
Old Oct 21, 2005
will somebody do a DIY for the manifold swap
Old Oct 21, 2005
andyman97's Avatar
Turbo Guru
Yeah, I just didn't want to fool with a piggyback anymore. I wanted to eliminate the ecu...always compensating and overcompensating fuel and timing. It's too much trouble to get consistant tune and power out of it. Plus, no CEL's
I may make a diy for the y8 mani later. No time right now.
Old Oct 21, 2005
02fpcivic's Avatar
well the only thing I can tell you is that I used the stock injector flange to port match, and realign holes to bolt it on. Everything else I did was custom, so as far as idle control, map sensor, injectors, linkage, IAT sensor, its all different on my car and would be of no use to you. You should put up a separate post to see if anyone can guide you in the right direction.
Old Oct 21, 2005
eye_see_you's Avatar
let the devil out
go andy .. thats awesome man. I would say I would keep sticking to it but i've decided to get rid of the boost etc and part out for my new project.. LOL
Old Oct 21, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
go D17 go!!!!
Old Oct 21, 2005
ncirom2003's Avatar
so is it the ems that keeps the stock ecu for some acc. or does it have those things so it completely kicks the ems out.
Old Oct 21, 2005
andyman97's Avatar
Turbo Guru
Cool man, I hope it all works out for you. When are you supposed to be getting it?
Old Oct 21, 2005
let the devil out
there is something else in the works besides what I spoke of.. a new project but don't worry i'm still keeping it in the honda family
Old Oct 21, 2005
dezod's Avatar
7thgen Power Maker
Final numbers???
Old Oct 21, 2005
Michalo187's Avatar
Abortion Survivor
yeah i want to know the final numbers **** dude so far they are awesome already
Old Oct 21, 2005
yourinmyw0rld's Avatar
Originally Posted by dezod
Final numbers???
Old Oct 21, 2005
tfnaaf's Avatar
BLDNPSI Mod
Nice progress Andy!
Old Oct 21, 2005
dezod's Avatar
7thgen Power Maker
That means they are still working on it.
Old Oct 21, 2005
wasn't that hours ago
Old Oct 22, 2005
Michalo187's Avatar
Abortion Survivor
what problems did you have with the plugs on top end??? Which plugs you using?
Old Oct 22, 2005
andyman97's Avatar
Turbo Guru
Ok....sorry guys, we weren't able to make another pass on the dyno, we ended up having to street tune with my PLX wideband. AEM datalogging ownz joo!
But seriously, the dyno broke. The brake on the rollers was stuck and it wasn't reading mph correctly, it was flipping all over the place so the only choice we had to finish was taking it on the street, so sorry I don't have any other numbers to post but the engine is tuned at 7-8 psi, and the boost cut is set at 8. We guesstimate about 205-215 whp. I'm going to try making it back up there next week for a couple of quick passes.
As far as the ignition issue, it wasn't the plugs, my tuner is more used to tuning dohc engines so he had too much timing pulled. When we were on the street, it was still wanting to break up a little, so he suggested advancing just a degree or two and that took care of the problem.
Old Oct 22, 2005
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
glad to see that you finally got everything going your way andy....i would love to see your ride again...maybe you can come see your folks when i come home for new years and we can get together in lake charles...keep me updated man...
Old Oct 22, 2005
02fpcivic's Avatar
sweet dude glad to see it worked out for ya.
