RSX-S axle-back on Sedan*** New question
Old Oct 12, 2005
Redviking's Avatar
Redviking is on a distinguished road
I am going to install a RSX-S axle-back on my 04 sedan
Do you have a special trick to make it fit under the sedan bumper without problem? (The civic oem exhaust bend down to clear the bumper). I don't like the idea of cuting my bumper to make it fit....
If I put longer hangers, will it hit my sway bar?
Anyone has a special trick to teach me?
Old Oct 12, 2005
rockhound124's Avatar
rockhound124 is an unknown quantity at this point
The only trick to putting it on would be to take it to a shop and have it welded on. The length is too short. A piece needs to be added to the piece between the muffler and the midpipe. A shop can do it right.
Old Oct 12, 2005
Redviking's Avatar
Thanks, but I already knew about this requirement to fit it to the existing exhaust.
My question is about the clearance with the bumper. On the a Sedan the bumper is lower than on a coupe (or at least seem to be!), so the muffler exit is curved down. Furthermore, sedan don't have a special hole for the muffler tip. If I attach my RSX exhaust on my car, the tip is directly in the bumper...
I guess I need to cut the bumper...
Old Oct 12, 2005
diskreet's Avatar
lol this is why i decided against this and got a $30 honda exhaust tip!
Old Oct 12, 2005
Redviking's Avatar
Old Oct 13, 2005
A good shop can extend the hangers and make it look good.
Old Oct 15, 2005
Redviking's Avatar
Flange fitment
I know that I need to add 2-4" to the axle back to make it flush with the bumber.
I know that I will need to use longer hanger...
But does the flange of the RSX muffler will bolt on to the OEM civic resonator flange? I know that the inner piping is larger on the RSX, but are the flange of the same size?
Old Jan 1, 2006
hdave's Avatar
hdave is an unknown quantity at this point
did u fidn ur answer to this question??
Old Jan 1, 2006
Redviking's Avatar
I read somewhere that the flange is not in the good angle, if you want to install the RSX muffler on the civic mid-pipe.
But, finally I will change also my mid-pipe for a RSX-S midpipe. So everything will line-up fine for me. My exhaust is still stock, but I started to collect all the part I needed, I have the RSX-S cat-back, a Kamikaze header, and a custom downpipe. I am just missing my high flow cat convertor to start my installation.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
