RSX-S axle-back on Sedan*** New question
I am going to install a RSX-S axle-back on my 04 sedan
Do you have a special trick to make it fit under the sedan bumper without problem? (The civic oem exhaust bend down to clear the bumper). I don't like the idea of cuting my bumper to make it fit....
If I put longer hangers, will it hit my sway bar?
Anyone has a special trick to teach me?
The only trick to putting it on would be to take it to a shop and have it welded on. The length is too short. A piece needs to be added to the piece between the muffler and the midpipe. A shop can do it right.
My question is about the clearance with the bumper. On the a Sedan the bumper is lower than on a coupe (or at least seem to be!), so the muffler exit is curved down. Furthermore, sedan don't have a special hole for the muffler tip. If I attach my RSX exhaust on my car, the tip is directly in the bumper...
I guess I need to cut the bumper...
Flange fitment
I know that I need to add 2-4" to the axle back to make it flush with the bumber.
I know that I will need to use longer hanger...
But does the flange of the RSX muffler will bolt on to the OEM civic resonator flange? I know that the inner piping is larger on the RSX, but are the flange of the same size?
Originally Posted by hdave
did u fidn ur answer to this question??
But, finally I will change also my mid-pipe for a RSX-S midpipe. So everything will line-up fine for me. My exhaust is still stock, but I started to collect all the part I needed, I have the RSX-S cat-back, a Kamikaze header, and a custom downpipe. I am just missing my high flow cat convertor to start my installation.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
junkyardguy
Sep 2, 2015 06:07 PM
