Suspension Installs
Suspension Installs
If anyone in the GTA needs suspension installed I can do it for a fee. This includes replacing springs and shocks. Any other installs are possible, and we'll work out a price. Email me below if interested, ask Gary about my handywork if you need a reference.
tomekdrob@gmail.com
416-843-7272
Located just north of Mayfield Rd, on Highway 10.
Thanks, Tomek
Here is my rate, which is quite reasonable:
$100, free install of front camber plates, rear camber correction bars $10 extra.
Free with suspension installation:
- tire rotation (if requested)
- air pressure check/adjustment
- visual inspection of brakes
- fluids check
- inspection of suspension components (ball joints, tie rods, compliance bushings).
Can replace:
- ball joints
- tie rods (inner and outer)
- compliance bushings
- timing belts, brakes
I can do everything but fit fiberglass bodywork, I stay away from things that I can't do to my high standards.
References:
http://www.7thgencivic.com/forums/sh...d.php?t=237460
tomekdrob@gmail.com
416-843-7272
Thanks, Tomek
- fluids check
Can replace:
- ball joints
References:
Originally Posted by MrXclusivE
ya man, I'll get them on the 14th. Come on msn biatchhh
Originally Posted by Axxe
Another happy customer. Tein SS springs without pillowball mounts, install went without a hitch, nice ride, and snow clearance. Have fun, but not too much fun
thanks for good install and awesome price.
Originally Posted by hdave
not interested but just curious.. how much to install shocks/springs?
- fluids check
Can replace:
- ball joints
Well, if you are doing TB you might as well put new accessory belts if the old ones are close to done. They need to be removed to change the TB anyway.
I have to check the shop schedule and see which weekend I can bring it in, although it will most likely be a Sunday afternoon, most likely two weeks this Sunday.
Also, I can get the parts you require from Honda at a discounted rate, so if you plan on buying the parts from the dealer, I can order them through my source. Roughly 20% less than dealer (before taxes).
this guy is a life saver, if u ever need anything done he can do it, this guys knows everything, i get most of my stuff done by him, and recommened many people, very responsible and will go out of his way if there is a problem to fix
Originally Posted by AlienX
throw me the prices with the belts, ill see how much i can get the belts for cuz i got a buddy that runs a parts shop..
lol, you can either do a belt right or wrong..
Im a FT student also, so Ill be in and around on weekends only..
If the tensioner is set incorrectly it can hold tension until the spring wears out and then releases the tension, which alows the belt to jump.
Waterpump can be installed incorrectly and leak 20+ kms down the road.
Torque specs can be way off (too high or low, both are bad), which can affect future servicability.
The bottom line is yes, it's right or wrong right away, but can go wrong in the future. I do it right the first time, because I take the extra 20 mins to make sure everything is aligned perfectly and done properly.
Originally Posted by tuan25000
hey i need my springs installed. where in toronto are you located?
The shop is located in Caledon, just north of Brampton. Basically it's 15 mins North on the 410 and an exta 5 mins on country roads.
hmm im from hamilton and it seems far. so is it 100 for springs install? can you do it if i come over tonight? lol
