Suspension Installs
Old Sep 26, 2005
Axxe's Avatar
Axxe is an unknown quantity at this point
Suspension Installs
If anyone in the GTA needs suspension installed I can do it for a fee. This includes replacing springs and shocks. Any other installs are possible, and we'll work out a price. Email me below if interested, ask Gary about my handywork if you need a reference.
tomekdrob@gmail.com
416-843-7272
Located just north of Mayfield Rd, on Highway 10.
Thanks, Tomek
Here is my rate, which is quite reasonable:
$100, free install of front camber plates, rear camber correction bars $10 extra.
Free with suspension installation:
- tire rotation (if requested)
- air pressure check/adjustment
- visual inspection of brakes
- fluids check
- inspection of suspension components (ball joints, tie rods, compliance bushings).
Can replace:
- ball joints
- tie rods (inner and outer)
- compliance bushings
- timing belts, brakes
I can do everything but fit fiberglass bodywork, I stay away from things that I can't do to my high standards.
References:
http://www.7thgencivic.com/forums/sh...d.php?t=237460
Old Sep 28, 2005
Axxe's Avatar
Can also do tune-ups, timing belt changes, everything but valve adjustment. Competitive pricing. Need to pay off OSAP.
Old Sep 30, 2005
saugashan's Avatar
This is not my batman glass!!
saugashan should not be trustedsaugashan should not be trustedsaugashan should not be trusted
i need some work done next year when i drop after winter.. will u still do it??
Old Sep 30, 2005
chohouston's Avatar
chohouston is an unknown quantity at this point
Gta?
r u in the GTA or kitchener waterloo??
how much for camber kit install?...b4 anyone says do it urself, im too lazy n dont have time!!
Old Oct 1, 2005
Axxe's Avatar
I'm in the GTA, should change my profile. Front or rear camber kit, or both? I'm not sure how long it will take, but I'm sure we can work out a good price.
Old Oct 1, 2005
chohouston's Avatar
i may need both springs and camber kit...once i find these i will give u a shout....pm me ur number axxe and we can work something out....
Old Oct 12, 2005
Axxe's Avatar
bump
Old Dec 11, 2005
Axxe's Avatar
Anyone still need suspension installs?
Old Dec 11, 2005
MrXclusivE's Avatar
MrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of light
me!!
Old Dec 11, 2005
Axxe's Avatar
Did you buy your Tein's yet?
Old Dec 11, 2005
MrXclusivE's Avatar
ya man, I'll get them on the 14th. Come on msn biatchhh
Old Dec 21, 2005
Axxe's Avatar
Another happy customer. Tein SS springs without pillowball mounts, install went without a hitch, nice ride, and snow clearance. Have fun, but not too much fun
Old Dec 21, 2005
hdave's Avatar
hdave is an unknown quantity at this point
not interested but just curious.. how much to install shocks/springs?
Old Dec 21, 2005
MrXclusivE's Avatar
Thanks man! its awesome, day and night difference from blown shocks to these. can't wait for a dry day so I can push it hard, No strange noises either, just got an alignment done and its all set.
thanks for good install and awesome price.
Old Dec 21, 2005
Axxe's Avatar
- fluids check
Can replace:
- ball joints
Old Dec 21, 2005
hdave's Avatar
^ good price.
Old Jan 14, 2006
Axxe's Avatar
Expert service still available on weekends.
Old Jan 16, 2006
AlienX's Avatar
AlienX will become famous soon enough
gonna need belts changed and I dont want to do it my self ... its too cold :P normally i do my own work but throw me a price and we can talk..
Old Jan 18, 2006
Axxe's Avatar
Timing belt or power steering/ac belts?
Old Jan 18, 2006
AlienX's Avatar
well, TB, the rest i can do in the spring when it gets warmer.. TB is more important since it can **** up the motor large..
Old Jan 18, 2006
Axxe's Avatar
Well, if you are doing TB you might as well put new accessory belts if the old ones are close to done. They need to be removed to change the TB anyway.
I have to check the shop schedule and see which weekend I can bring it in, although it will most likely be a Sunday afternoon, most likely two weeks this Sunday.
Also, I can get the parts you require from Honda at a discounted rate, so if you plan on buying the parts from the dealer, I can order them through my source. Roughly 20% less than dealer (before taxes).
Old Jan 18, 2006
i5r's Avatar
i5r
i5r is an unknown quantity at this point
this guy is a life saver, if u ever need anything done he can do it, this guys knows everything, i get most of my stuff done by him, and recommened many people, very responsible and will go out of his way if there is a problem to fix
Old Jan 18, 2006
AlienX's Avatar
throw me the prices with the belts, ill see how much i can get the belts for cuz i got a buddy that runs a parts shop..
Old Jan 18, 2006
Axxe's Avatar
Alright, I need to make some phone calls tommorow or friday, I'm at school full-time. I hope I can catch my parts guy.
Old Jan 19, 2006
MrXclusivE's Avatar
Axxe did my timing belt, his work is even better than the dealer!!!
Old Jan 19, 2006
AlienX's Avatar
lol, you can either do a belt right or wrong..
Im a FT student also, so Ill be in and around on weekends only..
Old Jan 19, 2006
tuan25000's Avatar
tuan25000 is an unknown quantity at this point
hey i need my springs installed. where in toronto are you located?
Old Jan 19, 2006
Axxe's Avatar
Not entirely true. A timing belt can be installed within 5* and still work, but it willl affect the powerband. IIRC D17 have room for 7* advance in cam timing and only 4* on the exhaust side (high interference motor, good efficiency), so if you are off one cog it can be disaster.
If the tensioner is set incorrectly it can hold tension until the spring wears out and then releases the tension, which alows the belt to jump.
Waterpump can be installed incorrectly and leak 20+ kms down the road.
Torque specs can be way off (too high or low, both are bad), which can affect future servicability.
The bottom line is yes, it's right or wrong right away, but can go wrong in the future. I do it right the first time, because I take the extra 20 mins to make sure everything is aligned perfectly and done properly.
Old Jan 19, 2006
Axxe's Avatar
The shop is located in Caledon, just north of Brampton. Basically it's 15 mins North on the 410 and an exta 5 mins on country roads.
Old Jan 19, 2006
tuan25000's Avatar
hmm im from hamilton and it seems far. so is it 100 for springs install? can you do it if i come over tonight? lol
