D3 Double X Brace: will it fit?
Old Sep 25, 2005
Redviking's Avatar
Redviking is on a distinguished road
Just saw that on clubrsx...
A Double X-Brace from D3:
The other braces for RSX or EP3 fit on our civic, so what about this one? Will the 2 others mounting point of this one also fit on a civic? It seems to be hard to install... but I guess it's good like this, if you want to brace it have to be tight!
reference: http://forums.clubrsx.com/showthread...hlight=x-brace or http://forums.clubrsx.com/showthread.php?t=235195
Old Sep 25, 2005
robbclark1's Avatar
Retired suspension supermod.
that guy pmed me at crsx telling me he could give me a good deal on a modified one to fit the em2. send him a pm.
Dr. Design
www.dthreedesigns.com
Old Sep 26, 2005
Redviking's Avatar
Thanks, I e-mail the guy for more info.
Pictures from clubrsx seem to be out... here another picture of the brace:
It's a bit like 2 Neuspeed X-brace welded together. The price seems to be good (185$).
But, I guess it's overkill for a street car... the Neuspeed or Tanabe brace should be enough...
Old Sep 28, 2005
Dr. Design's Avatar
Dr. Design is an unknown quantity at this point
YES! This will fit the EM2 Chassis!! Honda Tuning is using this same component on their racecar and street car!!! Also look for a write up on it in December issue. They really liked it.
Dr. D
Old Sep 29, 2005
Redviking's Avatar
From D3 website:
Tested on the track we have been able to greatly decrease understeer, virtually eliminate wheel hop, vastly improve steering response, and increase cornering speeds.
If the front is more rigid, it usually induce more understeer... no???
Material & Build: 304 Stainless Steel Tig Welded
So what's the actual weight if this big boy?
I am very interested in this brace... but maybe too hardcore for a daily-street-driven car!
Old Sep 29, 2005
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
From D3 website:
I was thinking of getting this too. But ya One would think it would cuase a little more push if it was stiffer. Maybe it keeps the flex out of the issue keeping the tires more planted in the corner. One day I will get one.....just gotta get my clutch first.
Old Sep 29, 2005
Dr. Design's Avatar
The weight is 8 lbs.
The reason for the decrease in understeer is because the bar reduces flex between the front cross member & chassis. The EM2 uses an engine cradle that is held in by a couple of large bolts. The Double X-Brace increases the coverage and simulates additional mounting points for the engine cradle. Under load there is a lot of flex on the EM2 chassis. When the chassis is allowed to flex it makes it almost impossible to properly tune the suspension. The chassis acts as an undamped spring! When you increase torsional stiffness you now direct the previously wasted energy to proper suspension locations. Essentially it allows the suspension to do its original job. Which gets back to your original question. By reducing flex in the front you will increase traction thus decreasing understeer! A lot of people say the vehicle becomes very nimble and responsive.
Dr. D
From D3 website:
Old Sep 29, 2005
Redviking's Avatar
More and more interesting!!!
How much clearance do we loose with this bar? (or how low is it sitting underneath the car?) Since the bar is 1" thick the bar I guess the brace is hanging at max 1.5" from the chassis?
Does it scrape over speed bump?
Old Oct 7, 2005
jamesandrew58's Avatar
Super Member
jamesandrew58 is an unknown quantity at this point
Yes it does fit.. i was the 1st person to have it on EM2.. Dr.Designs gave me a special price on it to test fit it on my car bak in the summer and yes it does work... here are some pics...
Old Oct 7, 2005
Super Member
Also my car is dropped on S-Techs (1.5 drop") and on the lowest part of the brace i only have 2" clearence and on the highest part of the brace i have 2 1/2" clearence
Old Oct 7, 2005
Redviking's Avatar
So, what's the feeling of the car with this brace? any noticeable changes?
Old Oct 7, 2005
Super Member
yes.... like when im on the straight.. before w/o the brace when i was crusing at 80mph i felt very instable and with this brace its very tight.. the steering is tight... when going into a turn its like a ferrari man.. it goes in and out w/ pleasure ...before when i used to pull hard w/ my car through a corner @ 40mph i had lots of tire squeek.. now that is very minimal
Also be shure u have time to install the brace... its is a definite bitch to put on.... heres my recommend way to install it
go from the 2 front LCA Bolts
to the 2 subframe bolts and
lastly to the 4 small rear framerail bolts
for the frame rail bolts if u cant get it aligned use a screwdriver to align the mount while u screw in the other bolt...
if u install the LCA bolts last u will have a hard time screwing the bolt back in... its near impossible... because the brace is very tight and if u dont have flexibility to work it the bolt will go in angled and push the metal up instead of screwing in and when that happenes u have to clamp the metal back together so it will align again...
Old Oct 7, 2005
Super Member
mods delete plz
Old Oct 7, 2005
gtracing's Avatar
TeLLy is my daddy
gtracing is an unknown quantity at this point
i heard it was a b!tch to put in...unless u have a hoist, or an access to a hoist, i wouldn't suggest trying this with just floor jacks...
hasn't anyone try to install a strut bar and it just doesn't ******* fit? it's the most frustrating thing in the world!!!
Old Oct 7, 2005
Super Member
u dont need a hoist my man.. all u need it floor jacks and ur set... u just need to just force.. FORCE IS THE KEY TO INSTALLING THIS BRACE!!! i used floor jacks btw
Old Oct 7, 2005
Redviking's Avatar
yes.... like when im on the straight.. before w/o the brace when i was crusing at 80mph i felt very instable and with this brace its very tight.. the steering is tight... when going into a turn its like a ferrari man.. it goes in and out w/ pleasure ...before when i used to pull hard w/ my car through a corner @ 40mph i had lots of tire squeek.. now that is very minimal...
I WANT ONE!!!!
But to ship it in canada I will pay twice the price for it....(shipment + custom fee)
Old Oct 7, 2005
Super Member
i live in hawaii so i was charged 35 for shipping but they said it cost them an extra 100 buxs but they already charged me 35 so they paid the 100... thats wat i call customer service... and ive heard that if u ever break ur brace it will be replaced for free!!
Old Oct 7, 2005
Redviking's Avatar
I checked rapidly and it would cost me around 300$US to have one.... (that's 350$CDN...)
Old Oct 7, 2005
Super Member
the brace is like 200 rite? i dunno it cost less for me and the shipping is like 100 cuz its so huge so that seems rite
u will love it though
Old Mar 25, 2007
slickstarnz's Avatar
slickstarnz is an unknown quantity at this point
Re: D3 Double X Brace: will it fit?
Anyone know if this will fit a sedan?
Gonna guess no, but thought I better ask just incase I get lucky
Old Mar 25, 2007
ragingSPAM's Avatar
I just burnt my tongue
i think im gonna have to upgrade to this from my tanabe one...the tanabe one works wonders too...but if i do get it ill prolly do some more reinforcement to it by boxing off the bars like the tanabe one
Old Mar 28, 2007
Redviking's Avatar
EM2/ES1(sedan)/EP3/RSX share the same chassis (or very similar) so it will fit!
HondaGuy7
Feb 22, 2016 01:00 PM
rayman009
Sep 12, 2015 08:30 PM
Biggunschad
Sep 11, 2015 04:06 PM
Ultra Havoc
Sep 9, 2015 10:58 PM
First Car
Sep 8, 2015 08:54 PM
