People That Install There Own Fog Lights Look Here (01-03)
Old Sep 12, 2005
IrockCivics's Avatar
I would like to know if there's a diy on how to cut the holes on the bumper for the oem fog lights? and if there is'nt one maybe you can tell me what did you use to cut the part off where the oem fog light goes at? and if it worth doing a diy or taking it to a shop better? I need detail's lol.. please help, thanks.
P.S. sorry if this is the wrong forum to post this.
Old Sep 12, 2005
dirtySAMURAI's Avatar
I log in from time to time
i used a drill with a small drill bit and drilled a **** load of holes around the perimeter of where i wanted the hole. then i took a utility knife and cut through the holes. then i took a file and smoothed the ridges so that i had a safer edge (no cutting fingers open).
if you're not used to using power tools or a knife, then don't try this at home.
Old Sep 13, 2005
Rufus's Avatar
Dremel
Old Sep 13, 2005
I might try it, thanks for the info.
Old Sep 13, 2005
boombazokajoe91's Avatar
I survived that B*tch Katrina !!!
boombazokajoe91 is an unknown quantity at this point
man i need to either get a new pair or get one of mine fixed one of mine cracked...
Old Sep 13, 2005
get it replaced under warranty lol
using a dremel would be the quickest and easiest way to undergo this project. i dont have a dremel, though, so i used what i had at the time - a drill and a knife.
Old Sep 13, 2005
ragingSPAM's Avatar
I just burnt my tongue
on my friends 03 i installed fogs...i had access to snap-on air tools so i used a rotary cutter and a di-grinder to fine trim the wholes...than i sanded it smooth with some 80 grit sand paper
Old Sep 23, 2005
how big do I have to make the hole for the fog light?
Old Sep 23, 2005
mrDFWmechanic's Avatar
i used a dremel and it cut throu that bumper like butter
Old Sep 28, 2005
manahoonie's Avatar
well, i just cut out the area that has the three smaller panels, and then placed the foglight over that area to see how much more i needed. it ended up being about 4 inches. you could probably get away with doing less. i used a hack saw to cut , and that went fairly easily. fast enoughto not tire out, but slow enough so you don't screw up. i also used a dremel w/ a cutting circular blade on it too. kinda hard to angle in though, so i used it for the vertical cut, seeing how i couldn't do a right turn with the hacksaw blade.
PM me for more/better instruction if needed!
Old Oct 2, 2005
I need to figure out how to wire the fog lights because mine came with no instructions. Any help with that will be greatly appreciated. Thanks in advance. I already cut the holes, and they look really nice. I just need to get the wiring done so I can start using them... Thanks again.
Old Oct 2, 2005
PunkingCivic's Avatar
I need TP for my bunghole
what fogs do you have the oem stlye or aftermarket. If there is a company get the directions from them.
got pix?
Old Oct 2, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
post a pic of the wiring.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
twtron
Apr 17, 2015 12:09 AM
AlpineCivic
111
Oct 20, 2003 07:31 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
disaster
Nov 7, 2001 05:30 PM
