L@@K at this turbo manifold
Old Sep 9, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
does anyone think this manifold would fit the d17? the pipes from the manifold are long and I dont know if its good like that because i remember the sf manifolds were awesome and wayy shorter.
Old Sep 9, 2005
diskreet's Avatar
the goal there is equal length though.
i have no idea on fitment but looks kinda cheap but the shape and design are nice
Old Sep 9, 2005
im stock now! T.T
yeah it seems as if i bolt on the turbo the piping would bend.. i dont know man i just wanted to hear from the boost junkies what this manifold seems like.
Old Sep 9, 2005
stinger's Avatar
Member
stinger is an unknown quantity at this point
ehhh its ok. THIS IS A MANIFOLD.
the pic is a crx but thats the kinda manifold i will build in my 7thgen. and yes i know ill need to remove the a/c, etc.
Old Sep 9, 2005
im stock now! T.T
so i would have to remove something with that manifold...
Old Sep 9, 2005
Logan3024's Avatar
Top mount manifolds wont work on a d17, Unless you want to cut a hole in your hood.
Old Sep 9, 2005
ragingSPAM's Avatar
I just burnt my tongue
that manifold is for a Bseries...unless u can mod it so it will bolt onto the D series block it wont fit
Old Sep 9, 2005
stinger's Avatar
Member
gonna be custom made my friend
Old Sep 9, 2005
civic01vtec's Avatar
The turbo is on the bottom.....not the top.
Old Sep 9, 2005
mxcivic's Avatar
mxcivic is an unknown quantity at this point
This manifold was done by a shop in mexico.... o and the shop sucks....
Old Sep 9, 2005
Rufus's Avatar
I need a turbo manifold. Anyone wanna sell one to me?
Old Sep 9, 2005
Logan3024's Avatar
What B-series?
Old Sep 9, 2005
Logan3024's Avatar
Aint no way the runners can be that long if its a bottom mount Ram Horn manifold.
Old Sep 9, 2005
andyman97's Avatar
Turbo Guru
Did you see the pic that mxcivic just posted? It's a full-race style on a 7th gen. And the turbo is a bottom mount.
Old Sep 9, 2005
ciVictoria's Avatar
That is one ugly manifold.
Old Sep 9, 2005
siharathb's Avatar
siharathb is an unknown quantity at this point
Is that a picture of scrappy's turbo manifold? I requested pics from him and that was one of them. Very weird shape.
Old Sep 10, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
color =
Old Sep 10, 2005
im stock now! T.T
yeah but still all this drama, people say it wont fit and people say it will. So do you think it will fit? judging by the other pic with the d17 eng ine, seems like it will fit. COlor dont mind at least if it makes some power.
Old Sep 10, 2005
Logan3024's Avatar
What does that have to do with the manifold Civic_RedLine posted?
RedLine, i dont think it will fit. The turbo flange looks a little to close to the manifold flange to fit a t3. And the manifold flange is thin as hell! Looks at mx's mani and youll see that his turbo flange is sideways.
Old Sep 10, 2005
andyman97's Avatar
Turbo Guru
What are you talking about? In the two pictures in this thread, they are BOTH BOTTOM MOUNT MANIFOLDS!!! I don't know what you're looking at but they are the same basic design. Nothing has a flange for the turbo on the side.
Looks like mxcivic's pic of that manifold clears ps pump and ac lines so that design will obviously fit.
As far as color goes, all you have to do is grind it down to the metal and jet coat it to get rid of the discoloration.
Old Sep 11, 2005
im stock now! T.T
will it fit?
Old Sep 12, 2005
TheSmuggler's Avatar
Ramhorn style. It provides alot of strength compared to other manifolds. It's similar to equal length but I don't believe it will net you quite the same gains. Anyways, watch this video of an Si near me. They custom made a ramhorn manifold for it. =)
Old Sep 12, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
You can get away without loosing a/c if you make all the pipes custom, Just either go the other side of the engine to the tb, or go under the a/c
Old Sep 12, 2005
turboengnr's Avatar
DONT PANIC
nobody would build and sell something that will never fit. So unless you got something from this sites favorite vendors (hahaha you know which ones i am talking about) then it will most likely fit.
Its a Full-Race/Kiwi/Lovefab style manifold.
it has the correct flanges on it. And it doesnt look like it will hit the block. There is a posibility that you will have to remove an accessory or two, but hey, anything for power, right?
It looks like you will have to remove the ac and/or ps. The mounting flage for the turbo is pretty close to the center. In order to keep the ac, i was making the flange pretty much directly underneath the #3 runner.
Old Sep 12, 2005
ragingSPAM's Avatar
that picture above is the H22 with a similar style manifold to the one on the first post
Old Sep 12, 2005
turboengnr's Avatar
DONT PANIC
i am talking about only the first post in this thread.
Old Sep 14, 2005
mrDFWmechanic's Avatar
ramhorn is way superior to log style manifolds. flows much better spools a lot quicker and just ownz log style manifolds. if you dont believe me then watch this video and see for yourself. http://www.panekmechanik.com/Videos/...old%20Test.wmv
Old Sep 14, 2005
iamboo's Avatar
Retired - SoCal FI Mod
i don't think you can prove that the ramhorn style is better with this video... the runners and the flanges on both the manifold have to be port matched to get an unbiased dyno run... not only that, the guys in the video could have done a lot of other things to the car while changing out the manifold such as installing a smaller downpipe or restricting the boost off the wastegate.... All i'm saying is... this video could be biased and shot strictly to sell more of their company's ramhorn style manifolds...
btw... tubular is better based on the physics
SammySC
121
Apr 7, 2017 07:43 PM
HondaGuy7
Feb 22, 2016 01:00 PM
jdh022764
18
Nov 3, 2015 06:44 AM
Mannimarco
Sep 7, 2015 10:01 PM
dantheman42
Sep 4, 2015 01:10 PM
