Question on installing true coilovers which use oem 01 uppermounts i.e. Tein and B&G
Super Member
On the upper mount there is an arrow, is this supposed to point in a particular direction when assembling the coilovers?
SEE ATTACHED PIC!
Also, is it supposed to point in a particluar direction when placing the mount up inside the car? The mount is a 3 bolt pattern, im assuming it can go in any which way.
Please help, thanks.
SEE ATTACHED PIC!
it doesnt matter where it points when you are building the assembly, unless you mean the specific order it has to go in, because once it's built, you can just rotate the hat to match the position in the shock tower. The arrow will then face the front of the car, but it can only go in one way, the studs are not equidistant.
Originally Posted by fuledya
It can only go in 1 way? I thought it didn't matter? Hmmm....
Originally Posted by goodtimes
wouldent it go on the left side sence there is a letter L for Left on it
reqy
Jun 1, 2015 07:05 AM
masongap
May 26, 2015 07:55 PM
