cruise control!!!
Old Feb 3, 2002
Todd1's Avatar
Todd1 is an unknown quantity at this point
cruise control!!!
when i try to use my cruise control, sometimes i cant set it!!!! i just have to keep hitting the set button, and it will eventually work!!!! it doesnt happen all the time!!! i am takin it to honda to fix it!!! just wondering if anyone else has had the same prob????
Old Feb 3, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
never happened to me
Old Feb 3, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
i've never even tried to use it.cruise control is dangerous
Old Feb 3, 2002
insan's Avatar
insan is an unknown quantity at this point
it works great,,becides the bulb not working on the cruze button....i messed it up changing it to blue
Old Feb 3, 2002
Stylingcivic's Avatar
Stylingcivic is an unknown quantity at this point
My cruise did that once. It happend about 2 months ago and there has been no repercussions.
Old Feb 3, 2002
Oishi's Avatar
Oishi is an unknown quantity at this point
never happened to me and i love using cruise control
Old Feb 4, 2002
joefufu419's Avatar
joefufu419 is an unknown quantity at this point
never have this problem before, but i dont' use it often, just once before
Old Feb 4, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
For the time I've driven my car, I've only used it maybe twice? I dunno... I don't use it since my car is a manual and I feel like I'm in less control. With automatics it's kew, but nah... haven't had that problem.
Old Feb 4, 2002
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
I love cruise, even with 5 spd. keeps me from speeding too much... But never had any problems with it.
Old Feb 4, 2002
UncleB's Avatar
UncleB is an unknown quantity at this point
I only use cruise control when I am going on long trips on the interstate. mine works great.
Old Feb 5, 2002
astr033's Avatar
astr033 is an unknown quantity at this point
<< i've never even tried to use it.cruise control is dangerous >>
What makes you say that CC is dangerous? Very strange...
I love cruise control and it works very well with a continuously variable transmission in hilly areas.
Back to the original post, I have had that same problem of the cruise control not clicking on right away when I press SET. I have no idea what's up with that. Did you get Honda to fix it? If so, what did they say?
Old Feb 5, 2002
AlphaInfinity's Avatar
AlphaInfinity is an unknown quantity at this point
Take it to the honda dealer and have them check it out. You mentioned trying to change the color of the light, and they may try to hammer you with the costs of fixing it because of that.
Old Feb 5, 2002
bzrollin's Avatar
bzrollin is an unknown quantity at this point
I know this sounds dumb, but if you have a stick, take your foot completly off the clutch. I used to have the same 'problem' until i realized that i still had a little pressure on the pedal. Maybe it was just me though.
Old Jul 8, 2002
Newbie78's Avatar
Newbie78 is an unknown quantity at this point
I have the same problem.
Brought it to the Dealer. They did nothing but waste my gas, time, and mileage.
They'll give you some excuse about you're setting your Cruise Control on too low of a speed and send you packing.
I think I may have found the source of the problem on my own.
The problem I think is related to the brakes.
The cruise control is canceled whenver you apply the brakes or the clutch.
How it knows if the brake or the clutch is activated I don't know.
For my car, I think what's happening is that I push down on the brakes but once I release it, it probably doesn't pop all
the way up back to its original position. So the cruise control still thinks that I have my foot on the brakes.
If I then try to push the brake upwards a little bit then I will be a set the cruise control again.
I'm going back to the dealer and show them my theory. Who knows what they will do.
Old Jul 8, 2002
djlunatic's Avatar
djlunatic is an unknown quantity at this point
Quote
[hr]Originally posted by: Stylingcivic
My cruise did that once. It happend about 2 months ago and there has been no repercussions.[hr]
me too!
Old Jul 9, 2002
pezzy's Avatar
pezzy is an unknown quantity at this point
I know this may sound stupid, but it was mentioned above. Make sure your feet are completely off the brake and/or clutch. When I had my Integra I had a "problem" with the cruise control not activating, it was to point where I would be bitching at the car while frantically pushing the set button. Then after this had gone on for about 2 months I finally realized why it would not engage....my damn foot would rest on the clutch.
By the way, if you have a 5spd make sure you do not pop your car out of gear (without pushing the clutch) while the cruise is on, the cruise will redline the engine until you stop it.
Old Jul 9, 2002
Jzero's Avatar
Jzero is an unknown quantity at this point
I have the problem where it seems like the buttons stick together. I cleaned them by running a damp rag in between the buttons and now it seems to work ok.
Old Jul 9, 2002
djmota's Avatar
cruise control kicks ***!! keeps me from going way too fast on long trips.
Good advise pezzy.I've wondered what would happen if you do that ,know I don't have to find out
Old Jul 9, 2002
WD40's Avatar
WD40 is an unknown quantity at this point
I use my CC on city streets to avoid speeding. Freeways are fair game though. &gt;
Old Jul 10, 2002
neoretromax's Avatar
neoretromax is an unknown quantity at this point
no one mentioned that there is a minimum speed needed before turning on cc. i believe it is 25 mph. correct me if im wrong.
Old Jul 11, 2002
LudlamTheory's Avatar
i boogie for the raindrops
i was testing it a while back out of curiosity.... 25 mph if you use the resume function, 30 if you use set.... try holding the det down for a sec when you use it... not just a quick click
Old Jul 12, 2002
dma001's Avatar
dma001 is an unknown quantity at this point
A buddy of mine used the cruise constantly in his 93 LX, speeding up and slowing down in regular city driving. Never had a problem with it. I use it occasionally, but only on the highway. It's great! [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jul 12, 2002
beamer's Avatar
beamer is an unknown quantity at this point
Mine works great every time.
Old Jul 12, 2002
DxMaN's Avatar
DxMaN is an unknown quantity at this point
Quote
[hr]Originally posted by: pezzy
By the way, if you have a 5spd make sure you do not pop your car out of gear (without pushing the clutch) while the cruise is on, the cruise will redline the engine until you stop it.[hr]
It's actually kinda funny when you use the 'resume' feature in a 5spd and you are in a low gear like 3rd. I think the car must be going 30mph or so, but if you had the cruise set at 70, the car really gasses it to get moving at that speed again. I tried different gears to see if it gunned it harder in the lower gears, but I think it limits the speed increase to like 5mph/sec or so. I guess to prevent throwing you back in your seat as it accelerates. Computer controlled drag racing...cool
Old Nov 7, 2011
stangholly's Avatar
stangholly is an unknown quantity at this point
Exclamation Re: cruise control!!!
Can any one help me out? I need the diagram for the cruise control, the mechanic repair version not the haynes. I have a 2001 civic lx. I wish my cruise control worked, so please any help?
Old Nov 7, 2011
Nosepicker's Avatar
Nosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the rough
Shoot, I wished mine worked. The light comes on when I push the button to activate it but when I try to set it I get nothing. My car's an AT.
I need cruise control for my long commutes.
Old Nov 29, 2011
stangholly's Avatar
I still haven't received any help, i know there has been links to it that people could not post. if those people could email it to me i would be greatly appreciated. I have a 1000 mile one way trip this Christmas and really could use the cruise control. Unfortunately can not pay some one at this time....
Old Nov 30, 2011
rodrj145's Avatar
rodrj145 is an unknown quantity at this point
im having the same problem myself, now it really sounds like a recall on cruise control mine wont work either it used to work perfectly not any more..
robjcivic
Mar 12, 2017 12:10 PM
junkyardguy
Sep 2, 2015 06:07 PM
JetsterDajet
Aug 16, 2015 01:56 PM
2010 Civic
Aug 10, 2015 10:53 AM
