quick & cheap ways to get some more power ?
What's up with my car ? I have 2000 miles on it now, but the loaner did as well.
What can I put on it or adjust to make it pull a little harder ? Don't want to go turbo route. I have an auto (b/c of my wife
) , maybe a chip will work or some kind of timing adjustment or ?thanks in advance.
Mitzysman
Born in the Island, Raised in the NYC.......Dominicano....Y Que??
Ummm, lets see, who wants to take this question? Anyone? Hello? I really dont want to answer this cuz it mite get ugly, so maybe one of u ricer guys, i mean NICER guys, lets this man kno the deal on quick and cheap hp...
your car is still under its break in period. 2000 miles is basically new. drive normally til its due for an oil change. then you can start considering better motor oil or stick with Honda motor oil 5w-20 and run it another 3000 miles to be safe. i believe theres something with addictives in the honda oil that helps your engine prevent premature wear? not sure...maybe just rumors?
as for mods, start off with the DIY cable throttle adjustment. itll give your pedal a better response with your foot.
I'll look for the cable mod in the DIY section... thank you !
ground kit will give you about .5-1.5 hp at 30 dollars so theres your best bet. then you can get a v2 or fipk2 intake theres 200 plus for 2 horses umm then theres trade it in for a car that will never get 40 mpg those cars tend to be faster.
mmm... that stuff sounds yummy.
Originally Posted by MitzysMan
thanks for the post. When is best to change the first oil ? Book says 5-10K but I wonder if 3 is better on the first one ? Would you say Castrol or what oil to put in .. the oil in it feels sticky to me.
don't go cheap on the filter... definately get one with a "drain-back" valve in it. this will be a piece of plastic/silicon covering the holes from the inside on the outer ring of the filter. it prevents oil from draining-back to the pan and causing a rough start.
There is no such thing as cheap fast ways to get power from our d17 the only way to get power is expensive and its called k20 swap or Turbo. As of now those are the only ways to get POWER. Cheap is no such word in the modification process of a d17. You can also go to diy and check out the throttle adjustment it helps a tiny bit and get a adjustable cam gear and advance the timing but seriously i would consider swap or turbo
tighten throttle cable
use fp60 from lubecontrol.com
get better header (kamikaze if you don't care about the cat)
get intake, K&N typhoon SRI is good for torque
jbradley4809
Apr 7, 2017 04:23 AM
RIPSAW
Nov 6, 2015 04:36 AM
beveragemp
May 25, 2015 07:11 PM
