Turbo guys please call out your DINO'S
Hey guys I just started buying my turbo parts today. Going to go with a home built turbo kit. But I need help from you turbo guys. Now one of the things I want to know is what your HP and TQ readings are and whats in your kits to give you your HP and TQ?
Also want to kow what you guys are doing about the fuel sys and E- Management?
Any help would be great and soon I hope to join turbo club soon
I have a few more:
1. Did you guys install your kits yourself or did a shop do it for you?
2. How hard is it to run the RSX injectors and what else will I need?
3. What is all this stuff and where can I buy it:boost harnesses and boost sensor?
4. Also do I need this stuff to run a turbo?
1. I installed it my self
2. Rsx injectors is the easiest part
3. This is just to read the boost
4. You need a boost controller
here is what your gonna need if you don't want to kill your engine
Greddy E-manage or Aem Ems
Rsx injectors
Boost controller
Turbo timer if you want to be really safe i have one and recomend one
Return fuel system is great if you can afford one but you can live without it
Make sure all your oil lines are good and you should be good to go if you have any other questions pm me
Rsx injectors
Boost controller
actually i think you will eventually need a return fuel system, my car is running rich enough to through cel all the time, and yeah i already had it tuned on a dyno, my tuner said it can't be leaned out enough to make it work
Well next Q's:
1. What intercoler do I need to use?
2. How do I run my piping?
3. Fixeruper how much did your E mang installed run you?
4. Did you install your kit, then take your car to the shop to get your e-mang or did you install your e-mang frist?
5. Are you guys running kits or building your own?
Well next Q's:
Sounds good ill see if I can find the book. What do you guys think about Nitrous?
I mean it will take me some time to get all the parts for my turbo and im going to rebuild right before I install my turbo. So would Nitrous make my car conpetive till I can get all my turbo together?
jbradley4809
Apr 7, 2017 04:23 AM
LionSpratt
Jan 29, 2017 11:07 PM
Wish I had a Turbo
