Retail Sales - site vendor annoucements Place for Vendors to post their specials and new stuff coming out or just advertise prices. These Vendors have been approved for posting in this section. Don't see anything new? PM them!
D17 Boost Essentials
Old Aug 26, 2005
dezod's Avatar
7thgen Power Maker
Crower D17 Stage 2 Turbo Special Camshaft for EX motors
Crower D17 Valve Train Upgrade for EX motors
Crower D17 FI Rods *Note these are not the Maxi-Lite Rods*
CP 9.0 Compression Ratio Custom Pistons
$2020 shipped anywhere in the 48 states.
OR
The Core Package: Rods & Pistons $1450 shipped anywhere in the 48 states.
Add an Innovate Wideband Standalone O2 Sensor Gauge kit for just $365
Post away! Call to order 954-757-7992
Old Aug 26, 2005
Michalo187's Avatar
Abortion Survivor
Arent the maxi light for non boost applications?
Old Aug 27, 2005
dezod's Avatar
7thgen Power Maker
I was told they can be used for boost as well, however I will double check with Crower.
Old Aug 29, 2005
fixeruper's Avatar
fixeruper is an unknown quantity at this point
a shame there's nothing for the non-vtec
Old Aug 29, 2005
dezod's Avatar
7thgen Power Maker
These will hold boost, but not in large amounts. 10lbs max probably.
Crower just confirmed an FI set of rods to handle higher boost.
Old Aug 30, 2005
Stachmo's Avatar
"You leave me in the trenches taking Grenades, John"
Stachmo is an unknown quantity at this point
do you have any other kits, or any plans in the future, to come out with a D17 engine build kit that could have us running up to around 15psi?
:edit:
I should state this another way. Do you guys plan on coming out with pre-put together kits that allow our D17's to handle x amounts of boost? Like you stated, the kit that you have listed would let us run 12-13psi of boost, Call it the stage 1 internals kit. I'm looking into prepping my engine to run around 15psi next summer, do you plan on making some sort of package deal so we could run this safely?
Old Sep 8, 2005
dezod's Avatar
7thgen Power Maker
:edit:
Yes we plan on releasing a stage II kit that will run 8-15 PSI, but are fumbling through the fuel portion of it now. The kit will not be released until this is done. It will include Crower FI rods. Pistons possibly too.
Old Sep 9, 2005
turboengnr's Avatar
DONT PANIC
i talked to crower about the maxi light rods when i ordered my moly ones. They said theyre safe up to about 15 psi. They will be great for a daily driven car!
Old Sep 9, 2005
dezod's Avatar
7thgen Power Maker
They will not stand behind it persay if you snap one because it was used outside of realm.
Old Sep 14, 2005
dezod's Avatar
7thgen Power Maker
bump!!!!!
Old Sep 14, 2005
zachgeyer's Avatar
bump bro
Old Sep 15, 2005
dezod's Avatar
7thgen Power Maker
Originally Posted by zachgeyer
bump bro
Thanks!
Old Sep 15, 2005
jbrown59's Avatar
CIVIC USER
jbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trusted
Ive read a little about these engine upgrades, and I know that some people are running there engines at 8psi without these upgrades and with stock engines. So are these upgrades really necessary or are these for people who will be pushin 10lb+ daily?
Old Sep 15, 2005
dezod's Avatar
7thgen Power Maker
The pistons and rods are required for boost levels exceeding 9 PSI daily.
Old Sep 16, 2005
Daemones6's Avatar
Daemones6 is an unknown quantity at this point
I saw a set up on here that is running 12psi dailing with stock internals.
Old Sep 16, 2005
dezod's Avatar
7thgen Power Maker
It is by luck. He is risking his motor internals and motor as a whole at that boost level daily. A buddy of mine with a D17 just blew up his motor running 9 PSI daily.
Old Sep 16, 2005
ncirom2003's Avatar
can you list exactly whats the pieces coming with this kit? (pistons and rods are obvious but whats in the valvetrain upgrade and the stage 2 turbo special (is it everything for turbo kit incl. intercooler manifold, piping, wastegate)?
Old Sep 16, 2005
dezod's Avatar
7thgen Power Maker
The package listed in the 1st post includes:
Crower D17 Valve Train Upgrade for EX motors (valve springs & retainers)
Crower D17 FI Rods (set of 4)
CP 9.0 Compression Ratio Custom Pistons (Includes pins, rings and locks)
OR
Old Sep 16, 2005
Daemones6's Avatar
I'm only runny 7.5psi now. going to stay that way until I get my tranny fixed.
Old Sep 16, 2005
ncirom2003's Avatar
OR
to what psi is this kit good to?
what would you say to not go above for daily driving?
and at these psi's do you think the tranny, axles are stable?
Old Sep 16, 2005
dezod's Avatar
7thgen Power Maker
300whp is the mark of death for the tranny.
If you had atleast the pistons & rods, you would be able to run 12+ PSI daily.
Old Sep 16, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
what is included in these:
Crower D17 Stage 2 Turbo Special for EX motors
Old Sep 16, 2005
dezod's Avatar
7thgen Power Maker
Old Sep 17, 2005
ncirom2003's Avatar
hmm 12 psi sounds good, how much hp do you think that would get an engine with just the turbo kit and your package to? (im not going to quote you on it im just looking for a guess)
Old Sep 17, 2005
dezod's Avatar
7thgen Power Maker
Well..........8 PSI on the T3/T4 has seen circa 180whp. 12 PSI, I would venture to say 215 or so.
Old Sep 21, 2005
dezod's Avatar
7thgen Power Maker
Bumper!
Old Sep 23, 2005
dbzkid84's Avatar
dbzkid84 is an unknown quantity at this point
post a new thread when you have a package that will go to 15 psi that is similar to this one that has a...
turbo cam
valve train
pistons
and rods (that support 15 psi)
thanks for the cool deal... i'll wait for the package with the new confirmed FI rods from crower.
Old Sep 23, 2005
dezod's Avatar
7thgen Power Maker
turbo cam
valve train
pistons
New FLASH: That is exactly what I listed in the 1st post of THIS thread.
The Crower rods listed in the 1st post will support up to 15 PSI easy.
Crower D17 FI Rods
Old Sep 24, 2005
dbzkid84's Avatar
oops! my bad! now you got me thinking... can you get your hands on darton sleeves for the d17 for that deal?
Old Sep 24, 2005
siharathb's Avatar
siharathb is an unknown quantity at this point
hmm how about if I get your t3/t4 turbo kit + aem ems + crower package?
pm me thanks =D
