How to get through firewall
Old Aug 16, 2005
Zeppelin8778's Avatar
Zeppelin8778 is an unknown quantity at this point
Hey Ive installed underglow neons recently and ive just had the cord running through the wheel well and in through the door, anyone know a good way to go through the firewall? a good place to puncture it? cuz i wasnt able to find a good place when i installed it.
Old Aug 16, 2005
civic01vtec's Avatar
Underneath the dash on the passenger side there is a rubber grommet in the firewall.
Old Aug 16, 2005
skipbarber's Avatar
yea, thats the easiest, pull the carpet up on the passengers side floor and there will be a massive gromment you can poke through. otherwise, you have to drill.
Old Aug 16, 2005
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
^^^Yeah the grommet, although it is pretty hard to get a thicker gauge wire(s) through there. If you need to drill go right under the brake assembly on the driver's side firewall.
Old Aug 16, 2005
Wizkid's Avatar
Wizkid is an unknown quantity at this point
you can get any gauge wire through with ease. the trick is to pull the grommet out into the engine bay, then use a long screwdriver to tape the wires to and push it through. I have done it 3 times now with no problems, an put up to 4 gauge wire through.
Old Aug 16, 2005
EnProceso's Avatar
the passenger side gromment is by far the easiest way. you can also drill a hole under the dash on the drivers side, i have wires going through both spots.
Old Aug 16, 2005
sofabolous's Avatar
sofabolous is an unknown quantity at this point
cot dam.. i wish i new this b4.. i poked a hole thru a small grommet on the drivers side when i was installing my fogs... was a pain in the neck trying to get to it
Old Aug 17, 2005
I put 0 gauge through plus wires for my boost guage and fuel system.
Old Aug 17, 2005
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
No screwdriver... Too hard, use a wire hanger. Gives you a whole lot more play. If it's like most connections for underglow, you are going to have to take apart the plastic clip on the end of the connector to fit it through the grommet.
Old Aug 17, 2005
SpecialEdCivic's Avatar
SpecialEdCivic is an unknown quantity at this point
The passenger side gromet is the best. I put 2 4 GA wires through mine. took 5 mins to get it through with some duct take and a wire hanger. good luck
Old Aug 18, 2005
brent_01civic_e's Avatar
brent_01civic_e is an unknown quantity at this point
i tired to find this out for almost a year.. i just didnt wanna cut into my firewall.. but thanks.. now i can use the way you all said
komodomichie
Jul 11, 2003 09:12 PM
Neofusion
Mar 23, 2002 11:34 AM
