water and oiil fed turbo
Old Aug 15, 2005
SuperFrankie's Avatar
SuperFrankie should not be trusted
okay i have a garrett t3 super 60 i know you can't just block off the water in and out (i wish you could) so where do i tap to get the water feed and return from on a 7th gen? thanks
Old Aug 16, 2005
turboengnr's Avatar
DONT PANIC
use the coolant lines that run through the throttle body. Run it through the throttle body, then through the turbo.
Old Aug 16, 2005
tfnaaf's Avatar
BLDNPSI Mod
Sorry for the HUGE pictures
Here you see it connected to the cyl head ..... Red econo hose end with stainless steel line
Here you see it connected to the Throttle body.......Red econo hose end with stainless steel line
HondaGuy7
Feb 22, 2016 01:00 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
Styven Szastur
Sep 23, 2015 05:26 PM
Bruce2
Sep 21, 2015 08:01 PM
