constant 12v source....
Old Aug 15, 2005
djspot's Avatar
fuk tha man!
djspot is an unknown quantity at this point
what wire in the harness where our decks are, or anywhere else for that matter, provide a constant 12v current source from the battery even when the car is completely off???
Old Aug 15, 2005
dj02's Avatar
there isnt any constant 12v source when the car is fully off.
Old Aug 15, 2005
ajhdragon's Avatar
7thgens official a$$hole
if yo uhave the honda civic electrical manual from honda there is an open space in the fuse box that is a constant 12v source. even when off. i want to say spot 13. but not sure i'll have to check when i get home.
Old Aug 15, 2005
um the battery is a constant 12v source. Just hook a wire to the positive terminal.
Old Aug 15, 2005
dj02's Avatar
ya but that will drain your batt lol.
i never knew about a open spot. that would make sense. damm i need my helm
Old Aug 15, 2005
djspot's Avatar
fuk tha man!
it will only drain your battery if the current is being used...that's what Im gonna do though, run a wire straight from the battery, I was just trying to find an easier route
Old Aug 15, 2005
KnocturnalEM2's Avatar
I am your Mom's Hero!!
Wire #10 or the White and Red Wire from the deck provides a constant 12v source and is Fused to #9 (10A) under the hood! Hope this helps!!!
Straight from Factory Service Manual...
Last edited by KnocturnalEM2; Aug 15, 2005 at 06:14 PM. Reason: Added Picture from FSM!
Old Aug 20, 2005
kumanan's Avatar
kumanan is a jewel in the roughkumanan is a jewel in the roughkumanan is a jewel in the roughkumanan is a jewel in the rough
dont hook up neon lights to it.. when the battery jumps to 13,14 vs... the neon will break.. unless you got a transformer for the neon that keeps it at 12V constant
Old Aug 20, 2005
i thought every neon has a separate or built-in transformer.
Old Aug 20, 2005
Da1lyDr1ver's Avatar
ok, i believe you're trying to hook up your headunit and not lose the memory when the car turns off right?
to get constant power all the time, even if the car is off... run the wire to the fusebox under the steering wheel. look for the fuse thats for the headlights. run the wire to that fuse and you'll have constant power all the time. this way, you wont have to run it throught the firewall.
if you dont understand me then just say so and i'll try to expalin better.
Old Aug 20, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
There are empty spots on the fuse box that you can use. Use a test light to find them.
Old Aug 20, 2005
djspot's Avatar
fuk tha man!
so you guys know, here's what Im doing....if ya'll have an xbox or such in your car you know unless you hook your inverter directly to your battery, you know its a bitch that everytime you just go to ACC with your car and then crack up again, the inverter restarts because power is cut out...well I figured out how to have it so that doesnt happen, but I need constant power to achieve this...
for anybody that may be wondering, here's how to do it...
tap into an ACC line and an IGN line, put a diode on each and then combine them to make one connection. Then place a fuse to be safe, then wire up a standard 12v bosch type relay...now when you crank up your car your xbox or anything else you have hooked up to this wont turn off during crank...I'll do up a good diagram just now, and post it...
Old Aug 21, 2005
skipbarber's Avatar
i dont think id grab constant at the radio for that purpose, go to the fuse box or ignition harness instead.
Old Aug 21, 2005
CivicSky's Avatar
CivicSky is an unknown quantity at this point
one of the constant 12v sources on the fuse box is the spot # 3. Trust me on that. I am using it
Old Aug 21, 2005
djspot's Avatar
fuk tha man!
here's how to wire this whole thing...
h4ldol
Apr 24, 2017 08:16 PM
68camerors
Sep 24, 2015 06:18 PM
BJB
Sep 14, 2015 11:16 PM
Bricoleur
Sep 9, 2015 12:23 PM
