Once you go black, you never go back
Old Aug 14, 2005
nooboob's Avatar
nooboob is on a distinguished road
Or so the saying goes...
If I were to paint my head and rear lights black, will I be able to go back to reg. stock?
Old Aug 14, 2005
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
you want to paint your rear and headlight housings black? or do you want to paint your rear and headlight bulbs black? either way after painting them you can't go back to stock without buying new or used stock replacement parts.
Old Aug 14, 2005
jttegx's Avatar
OMNES AD UNUM
im sure you can use a paint thinner or something that removes paint without harming the material. but its just a lot of work. mainly the headlights... bake them in oven to get heated, paint, reseal...then its reopen/rebake, spend hours removing paint on the housing, and reseal. im not sure if the chrome housing would peel or not using paint thinner
for tails, it should be easy. its just a spray on with coatings
Old Aug 14, 2005
GreatWhite02's Avatar
4 cyllinders are good but 5 is better!
GreatWhite02 is an unknown quantity at this point
yeah the chrome plating on the headlamps will rub off with paint thinner. It happened to me! Make sure this is what you want to do unless you want to cop an extra set of lamps in case you mess up.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
cmart1209
May 29, 2015 04:52 AM
drhawkinz
May 16, 2015 11:39 AM
cdt12271
Apr 23, 2015 11:36 AM
