Slighty Bent Radiator
Pwning Noobs 24/7
well i got into an accident today, and my radiator is slighty bent, resembles a slight curve, does not leak, car doesnt overheat, still is cold when starting looks intact, do u guys suggest replacing it ? Or just leave it
Like Streetglower said, if the insurance is paying, get a new one!!!
Otherwise check for leaks, I generally get a large piece of cardboard, pull the front of the car over it after I have driven it for while and let it set on top of the cardboard for a while (overnight if possible). Then check for wet or discolored spots that wre not there before, helps if you have a garage too. I was fooled into replacing a raditor once, when the dog next door unrinated on the cardboard.
But also pressure test the system. that can tell you if there is a leak.
solarpunk70
Apr 12, 2016 11:43 AM
260000milesgoal
Sep 25, 2015 07:41 PM
