water boiling sound from front...
Old Jan 31, 2002
deuky's Avatar
deuky is an unknown quantity at this point
when I pushed my accelerate pedal little bit, water boiling sound from front body.
maybe it is not engine sound. It sounds like boiling water or little stons are rolling.
It mixed with engine sound...but when the RPM be over 2000, it disappear....
It sounds like .. boiling water or rolling little stones...'gagle, gagle, gagle...'(very fast)
Anyone help! civic2001 2door 9000 miles
Old Jan 31, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
<< After starting engine and long stoped for sign staying, whenever happen it when I pushed my accelerate pedal little bit... >>
i'm having trouble understanding[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 31, 2002
insan's Avatar
insan is an unknown quantity at this point
sound like something for the deal to handle
Old Jan 31, 2002
Ronin's Avatar
Ronin is an unknown quantity at this point
I'm having trouble understanding too...
Old Jan 31, 2002
deuky's Avatar
Sorry cause my broken writting...[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
I rewrite that..
Old Jan 31, 2002
01LX's Avatar
01LX is an unknown quantity at this point
Why you boiling water, to cook instant noodles on the go?[IMG]i/expressions/laugh2.gif[/IMG]
Old Jan 31, 2002
SoFlaCivic's Avatar
SoFlaCivic is an unknown quantity at this point
Does it sound like a can of marbles??
That could be pre-ignition or detonation, which could be bad for your motor.
Do you live at a very high altitude?
Perhaps you need to run a higher grade of fuel.
Have the dealer take a look at it, if it's a repeatable problem.
Good luck!
Old Feb 1, 2002
vistec's Avatar
vistec is an unknown quantity at this point
i have the same problem, not very loud sound, i can only hear it if i am accelerating in first gear and under 2000rpm...sounds like boiling water...
deuky, is you car stick or auto...we gotta find out what the problem is before the car is f%$ked...
Old Feb 1, 2002
netranger's Avatar
netranger is an unknown quantity at this point
Ya Ya Ya I have the exact same thing, it's not detonation, i know that for sure, its muted but sounds like rocks rolling through the tranny or engine. My dealer said to leave it with them next month, we'll see what they say. If anyone finds out what this is please let me noe!!
Old Feb 1, 2002
netranger's Avatar
Mine is manual Lx , started at about 12000 km, at 16000km now!
Old Feb 2, 2002
vistec's Avatar
mine is manual si (EX in US)...do you have a short shift adapter...i do maybe that is messing something up???
Old Feb 3, 2002
vistec's Avatar
anyone else with this problem...if your want to see if you have this problem, get in your car, turn off the radio and start to accelarate slowly a listen to the engine...that is how i noticed, you wont hear it if you got the radio on....
Old Feb 3, 2002
netranger's Avatar
There are no mods to my car, so it is not your adapter
Old Feb 4, 2002
deuky's Avatar
my car is auto.
Old Feb 4, 2002
vistec's Avatar
have any of you guys taken your car into the dealer yet?
Old Feb 5, 2002
vistec's Avatar
ttt
Old Feb 5, 2002
chewsciv's Avatar
chewsciv is an unknown quantity at this point
i have an auto EX and my car does that sometimes.. it seems to me like the sound is coming from the right side (from inside the car) like behind the glove compartment... my Dad said it might just be a bit of air in with the radiator fluid so it gurgles a little. I also noticed that sometimes it seems to be worse when it is colder and the heat is on, perhaps something to do with it? i dunno
Old Feb 6, 2002
vistec's Avatar
that is exactly how mine is...but it should be checked out before something goes really wrong...
Old Feb 6, 2002
VanDizKo's Avatar
VanDizKo is an unknown quantity at this point
I have the same problem with my Civic EX coupe. Nothing to be worry about because I know it is not denonation, because I always used 93 octane fuel, but I know it has to do with heat. My theory is that the noise comes from the header heat sink due to rapid high temp causes the heat sink to expand, and when it cools down, it sinks and makes metal cracking likes noise. However, my theory might be wrong because when I drove my car for five minutes in snow, and parked I heard the noise. It can't be because my car can't not be that hot when I only drive for 5 minutes and in the cold. I'll bring my car to the dealer to check it out. Update if you get the info.
Old Feb 6, 2002
Lightning's Avatar
Lightning is an unknown quantity at this point
Old Feb 7, 2002
ayzan's Avatar
ayzan is an unknown quantity at this point
Hey guys, I just noticed that water noise today. There's probably some air trapped in the heater core unit as the coolant is being cycled. If you turn the heater temperature to hot and raise the rpms to 2000 or so, you'll hear it. When you turn the heater temperature to cold, you won't hear it anymore. Basically what's happening is when you turn the heater to the hot position, the coolant cycles from the engine head to the heater core inside the dash. The hot coolant heats up the heater element and you get hot air through your vents. The noise you hear is just the coolant being cycled through the dash. If you turn the heater off, it will close the valve and stop the coolant from cycling. Now you will not hear the noise.
More than likely, bubbles are trapped in the heater core and that is why you are hearing the boiling sound.
Try bleeding the cooling system and if that doesn't work, you might want to take it to the dealer to get it checked just to be on the safe side.
As long as there is no coolant loss, and the coolant's color is normal, then there is nothing to worry about except a little bit of air.
Old Feb 8, 2002
normaspirated's Avatar
normaspirated is an unknown quantity at this point
<< i have an auto EX and my car does that sometimes.. it seems to me like the sound is coming from the right side (from inside the car) like behind the glove compartment... my Dad said it might just be a bit of air in with the radiator fluid so it gurgles a little. I also noticed that sometimes it seems to be worse when it is colder and the heat is on, perhaps something to do with it? i dunno >>
That's EXACTLY how I can describe it too. When the car starts moving slowly from a dead stop either in first or reverse gear, I can hear some liquid moving around and it sounds like it's coming from the engine bay on the passenger side. It kind of sounds like ice cubes swishing around in liquid and banging off the walls of a cooler. Sorry, that's the only analogy I can think of
Old Feb 8, 2002
vistec's Avatar
i got to try the heater thing...let you know how it goes...
Old Feb 8, 2002
smoke's Avatar
smoke is an unknown quantity at this point
THAT'S WEIRD, I JUST NOTICED THAT NOISE THE OTHER DAY AND I JUST DECIDED TO LOOK AT THE 2K1 CIVIC SITE TODAY TO SEE WHAT'S BEEN GOING ON SINCE I HAVENT HADE A CHANCE TO USE THE NET, AND IT JUST HAPPENS THAT OTHER 2K1 CIVIC OWNERS ARE HEARING THE SAME THING COMING FROM SOMEWHERE IN THE DASH THAT I AM. I MESSED WITH THE **** FOR THE TEMPERATURE CONTROL WHILE THE AIR WAS OFF AND WHEN I TURNED IT ALL THE WAY ON HOT AND REVED THE ENGINE THAT SEEMED TO BE THE ONLY TIME I HEARD THAT NOISE BECAUSE WHEN I TURNED IT ALL THE WAY ON COLD AND REVED IT I DIDN'T HEAR ANYTHING. I DECIDED TO TRY THAT BECAUSE I REMEMBER WHEN I OWNED MY 82 SUPRPA EVERYTIME I WOULD MESS WITH THE TEMP WHILE THE AIR WAS OFF TURNING IT FROM HOT TO COLD IT WOULD RELEASE SOME KIND OFF PRESSURE THAT WAS BUILT UP. BUT I DON'T KNOW . i GUESS JUST LISTEN TO THE DIFFERENCE WHEN YOU TURN IT ALL THE WAY FROM HOT TO COLD WHEN THE AIR IS OFF. JUST MESS WITH THE *** WHILE YOU REV IT UP A LITTLE
Old Feb 10, 2002
vistec's Avatar
it works!!! turn the temp **** to cool and the noise is gone...but still got to find a way to get the air out of the heater...[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 10, 2002
Ronin's Avatar
<< Try bleeding the cooling system and if that doesn't work, you might want to take it to the dealer to get it checked just to be on the safe side. >>
How do you "bleed" the cooling system?
I just started hearing that sound for the first time today (after 10 months of ownership)... it sounded like dripping/running water... coming for inside the dash on the passenger side. And ya, I think ayzan is right. If you reach in behind your glove compartment (when it's open), you can feel a large pipe there that carries the coolant for your heater. So the sound probably originates from there.
Old Feb 11, 2002
vistec's Avatar
....but how to get rid of the sound?....
Old Feb 11, 2002
Ronin's Avatar
Didn't hear the sound anymore this morning... had the heat blasting cuz it was freakin' COLD (-20 degrees celcius) and didn't hear a thing. I wouldn't worry about it too much, if I were you. You could always take it in to your dealer, but chances are they will say they cannot recreate the sound or the problem, so why bother.
Old Feb 12, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
i listened for the sound the other day and i couldnt hear it
<< I know it is not denonation, because I always used 93 octane fuel >>
why are you wasting your money?? send it to me instead. civics were designed for 87 octane, youre supposed to use that. using anything higher 1) costs more 2) lowers gas mileage 3) has absolutely no benefit whatsoever for your car, and could actually be harmful
Old Feb 13, 2002
GustavSi's Avatar
GustavSi is an unknown quantity at this point
My started to do near the end of summer to autumn. It has stopped since (close to the end of autumn) I had brought it to the dealer but they were not able to recreate it. Morons.
My 94 dx coupe was doing it too.
