2002 honda civic lx 4door
Old Aug 2, 2005
james mauldin's Avatar
james mauldin is an unknown quantity at this point
hi, i just got some coil overs for my car. Someone told me that i need to replace my shocks with new and install a camber kit on the front and back so that my car ride better and hold a alignment. Is this all ture???????
Old Aug 2, 2005
scarypunk's Avatar
scarypunk has a little shameless behaviour in the past
yes and no, you may or may not blow your stock shocks on your car - depending on how low you go, also same with camber kit.. i would sugguest getting camber kit for the rear at least .. if you drop more then 1.5 i would highly recommend getting aftermarket shocks as well ..
Old Aug 2, 2005
camber kit is required if you value your tires. You cannot properly align a car without one if you're lowered. There are always exceptions, but thats a general rule. Shocks is up to you or wiat until the stock ones blow out. Keep in mind the stock shocks were designed for the stock ride height.
Old Aug 2, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
someone didnt read the suspension faq b4 they bought their stuff
Old Aug 3, 2005
Mike813's Avatar
Mike813 is an unknown quantity at this point
you should check the manufacturers websites of the springs youre getting, majority of them has a chart that tells you whats needed etc etc, but imo and like what everyone said above, anything over 1.25 will need a camber kit + new shocks, reason i say 1.25 most springs eventually sag/break in over time and itll end up with 1.40-1.5 later in life, tires will eventually bald unevenly, and a nice hit on a pothole with oem shocks will blow those suckers out in under a year....
performance springs have different spring rates (stiffer than oem) picture a 500lb guy jumping in a pool meant for kids so yea...
Old Aug 3, 2005
robbclark1's Avatar
Retired suspension supermod.
I just love people who buy parts that have no idea what they are doing...learn before you buy, NOT AFTER! You can make your car very dangerous to drive if you mess with your suspension the wrong way.
jessicakaybby
Apr 20, 2015 12:11 PM
vino
Nov 3, 2001 11:08 PM
