Another door lock actuator question
Old Jul 26, 2005
nitsuj1604's Avatar
nitsuj1604 is an unknown quantity at this point
ok so thru reading and searching it seems that even if an aftermarket actuator works sometimes, the actuator could still be dead because every now and then the brushings touch each other (can someone explain?). Bought the car ('00 dx)used from dealership the other day and found some hanging wires hidden and found they lead to door lock actuators. They both make noise, they have never actually unlocked or locked the doors but usually the actuator arm moves in and out when it is not mounted or cover screwed on all the way. is there any other possibilities? if it helps, they are reverse polarity actuators.
Old Jul 26, 2005
AlpineCivic's Avatar
Its possible that you have bad actuators. The actuators move when they are not mounted because they have no load on them therefore not neading much to get them to move. If they make noise when they are installed (grinding noise) it can be 2 things:
1) Improper installation! If the actuator is mounted to where it can not fully extend or retract all the way then you will get a grinding noise. 2) You simply have bad actuators. The grinding noise comes from damaged internals that can cause by improper installation, water damage or cheap brands.
h4ldol
Jun 3, 2015 03:26 PM
maaronia
May 14, 2015 10:46 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
Killagi
Apr 12, 2015 10:42 AM
