Over weight rims
Old Jul 24, 2005
HEBEGEBZ's Avatar
HEBEGEBZ is an unknown quantity at this point
Question Over weight rims
I was just wondering what you guys think is too heavy for an 18" wheel. Keep in mind that I am dealing with the fact that my car is not fast, so the track is not a factor. Well, for now anyway . I guess stopping distance is my biggest concern. Although I don't want it to take for ever to pull away at a light. If you have what some would consider heavy rims please post there size and your feelings about there daily driving performance. Thanks
Old Jul 24, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
21 lbs or more I'd say is heavy
1 lb per inch is good
Lighter than that is really good.
Old Jul 24, 2005
HEBEGEBZ's Avatar
Anyone know how heavy 18" Seki G-Racing wheels are
Old Jul 24, 2005
Jap-Euro Fusion
Well lets put it this way... They're cast knockoffs of forged wheels. In this case, Volk CE28Ns, which the 18x7.5" version tips the scales at 16lbs. Considering that they're taking a forged design and casting it, they need to add strength to it because castings don't hold a stick to forgings in the strength department. So what do you do? Add more aluminum. Considering the way Volk makes wheels, probably add lots of it. I'm going with a bet of no less than 20 Lbs.
Reverse engineering only works well if you improve upon what you find. In the case of knockoffs, you're really reversing it, then going back further. Its really not a winning combo.
If you're worried about braking distance, get smaller wheels. Inertia of big wheels is a bigger enemy than overall weight. Your brake torque doesn't change, but a bigger wheel adds more inertia it needs to stop, so it takes longer. A 25 lb 15" wheels takes a shorter distance to stop than a 25 lb 18" wheel and takes a lot less distance than a 75lb 24" spinner.
Old Jul 24, 2005
thoughthard's Avatar
thoughthard is an unknown quantity at this point
Possibly 19.6lbs, according to a quick search on the Internet. Hyper-black if that matters any.
Old Jul 24, 2005
HEBEGEBZ's Avatar
Just found out that the wheels i really wanted are 26lbs. I guess I go back to the drawing board. That choice was made on looks alone.
Old Jul 24, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
ouch! 26 lbs will definately hurt!
Old Jul 25, 2005
HEBEGEBZ's Avatar
Finding that out really hurt. I knew they would be heavy but 26lbs never crossed my mind. And they don't make a smaller size
Old Jul 25, 2005
Zzyzx's Avatar
Autocross Junky
Personally I dont really see the point in worring about the weight of an 18" wheel.... as the overall weight isnt the problem, its the Inertia. (the cars not going to be fast with any 18" wheel... so why worry about how heavy it is?)
Old Jul 25, 2005
ctv's Avatar
ctv
ctv is an unknown quantity at this point
my Konig Hurry's are 16lbs ea for 17x7
i just swapped to Konig Heluims 15x6.5 and are 10lba ea!
Old Jul 25, 2005
HEBEGEBZ's Avatar
I really don't know. I have just heard bad things. I don't know much about this at all. It just seems to me that to get a wheel that size and that heavy to start and stop moving would cause the car extra strain.
Old Jul 25, 2005
HEBEGEBZ's Avatar
does anyone else think having 26lb rims on a civic is not a problem
Old Jul 25, 2005
there really isnt a problem. A lot of ppl on this forum have 18's and 19's. It's just extra weight to lug around....
Old Jul 25, 2005
HEBEGEBZ's Avatar
So i just swap wheels when it is time to go to the track?
Old Jul 25, 2005
^^ you can do that if you want... or you can keep them on to see what you run with 18's.
Old Jul 26, 2005
aznpoopy's Avatar
aznpoopy is an unknown quantity at this point
your car will be considerably slower with a heavier wheel
its not just weight
its unsprung weight
rotational inertia
every lb really counts when it comes to wheels
Old Jul 26, 2005
tfnaaf's Avatar
BLDNPSI Mod
Centerline RPM's !!!
Old Jul 26, 2005
HEBEGEBZ's Avatar
I know those are forged wheels but how heavy are there 18s
Old Jul 26, 2005
tfnaaf's Avatar
BLDNPSI Mod
My 18's with tires weigh less than stock 14's and tires! I forget what bare rim weight is, something like 15 lbs???
Old Jul 26, 2005
HEBEGEBZ's Avatar
they are not that expensive either. I also like the vantage wheels
Old Aug 2, 2005
Robb989's Avatar
Robb989 is an unknown quantity at this point
I have 18" Motegi RT5's, I don't know how much they weigh, but when I put them on I felt a slow down.
Old Aug 8, 2005
mdb_foxmx's Avatar
mdb_foxmx is an unknown quantity at this point
you'll notice that your car won't accelerate nearly as fast as it does with stock rims/tires because of two things:
a) yeah, if the weight of the wheel goes up, then that adds to rotational inertia..a bad thing for accelerating.
b) more of the mass of the wheel/tire will be concentrated further away from the center of the rim, which will REALLY add to rotational inertia (I = cmr^2), depending on how much further away this is than stock.
IMHO, 18's are a little big for our engines. maybe if you swapped a k-series you'd be ok, but I get pissed everytime I have to go up a hill, and I've only got 16's. I'd never buy bigger than a 16" rim for this engine, but I suppose some might be able to get by with 17s, or even 18s.
Old Aug 10, 2005
boombazokajoe91's Avatar
I survived that B*tch Katrina !!!
boombazokajoe91 is an unknown quantity at this point
i got 18's and i can care less about the weight.. im not trying to race anyone...
Old Dec 11, 2005
Tbag's Avatar
Tbag is an unknown quantity at this point
All the above reasons is why I'm selling my 17's and getting light weight Rota wheels in 15" = 12lbs
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Wariogamer
Sep 29, 2015 09:49 AM
Balkos
Sep 11, 2015 11:39 PM
