R32 and SpecV backed out so I raced my friends 450+hp SRT on low boost
AKA Mr. 60ft. Not to be confused with Civic_Redline
I was supposed to race an R32 and a cammed all motor spec V that both run somwhere around high 13's to low 14's. Well they both backed out and want to do it at the track next fri. So since nobody wanted to race me or my friend. We decided to race each other. He said he would leave it on low boost, so I agreed to waste my N20 in the name of fun. 8psi on a (edit) T3/T4 60trim with a 61mm wheel. He ran mid 13's with this setup before. From a dig we go pretty even off the start, by the end of first he is ahead slighly with his door panel at my front bumper, shift to second and hit the switch, he pulls ahead and my front bumper is right at his rear bumper, third through 4th he pulls ever so slightly, by 115 he is still about a car ahead of me and I shut down.
We went again this time he turned the high boost on(20#s)=450+HP
, I actually had him out the hole but as soon as his turbo spooled he left me like I was standing still
. Aiming for 13's this friday at the track
Oh yeah forgot to mention I put the 50shot in and damn does it hit hard. Speed limiter comes up real quick now.
Got video. Need to get to host then I'll link it.
Originally Posted by Redline04
I was supposed to race an R32 and a cammed all motor spec V that both run somwhere around high 13's to low 14's. Well they both backed out and want to do it at the track next fri. So since nobody wanted to race me or my friend. We decided to race each other. He said he would leave it on low boost, so I agreed to waste my N20 in the name of fun. 10psi on a T60 with a 61mm wheel. He ran mid to high 13's with this setup before. From a dig we go pretty even off the start, by the end of first he is ahead slighly with his door panel at my front bumper, shift to second and hit the switch, he pulls ahead and my front bumper is right at his rear bumper, third through 4th he pulls ever so slightly, by 115 he is still about a car ahead of me and I shut down.
! my high boost is a bitch
but i run a low 13 on low , so u should be good for a 13,sec run . Last edited by ShiftySRT4; Jul 24, 2005 at 01:56 PM.
Originally Posted by ShiftySRT4
Nice Run REDLINE
but i run a low 13 on low , so u should be good for a 13,sec run .i gaurantee you weren't running any better than a high 13 second pass the first time you ran him. and even that is a stretch.
Originally Posted by KnocturnalEM2
Nice...you can use Megaupload for you video!!
Mine is the same as here!! Havent posted there in a while...trying to get my car in order for the Nor Cal chapter with Stephen!!!
I ran a 13.8 with a 65 shot in my EM1 Si when it had the B16A2. So not only did I start out with 160BHP, and 85lbs less (stock curb weight), but the gearing for the 99-00 Si is exactly the same as the USDM ITR minus the LSD. Read: a lot better then yours. I really doubt that your car will be pulling a 13 anything at the rack with just a 50 shot and bolt-ons.
BTW: I was piloting the car to consistent 14.9s' when all it had was just an AEM CAI and suspension upgrades, so yes, I do know how to drive the car.
Your car now has something it didn’t before… torque. That’s why its deceiving as to how much faster the car is. Trust me, go run it at a real track and you will find this out for your self.
If I had to guess you would probably be running mid-high 14s on a well preped track.
did you ever see the stock exhaust manifold? There is no doubt in my mind that I would have picked up a few 10ths like you if I had changed out my stock h/e.
his 15.1 na is in question at the moment.
nitrous will not improve your 60' time. unless you are using nitrous off the line and have the traction to handle it.
Originally Posted by scansel912
Theres no reason why Redline04 shouldn't be able to go from a 15.1 N/A to low 14's high 13's with nitrous.
good run. Good luck with the track. I just wanna break 14's lol. I already put the jets in and i was gonna spray in 1st but msd ws and stock tires =
. Anyways great run and post the vid
. Anyways great run and post the vid I would spray in first. WIndow switch was set to come on at 4K RPM, but that didnt matter since Id slip clutch launch at over 5500. Traction was never a serious problem... and thats with a 65 to 70 shot. Id usually pull 2.2s on street tires.
Launch at around 3000 in our cars depending on how good your tires are. Let me know what tires your using. I launch at like 3000-3200 and just spray once I get traction. But ive only been to the track twice with NOS so theres room for improvement.
Originally Posted by allmotor
r u serious? Everyone tells me to launch at 3500-4000 w/o nitrous and if i spray in 1st then launch at 2000??????????????
This technique accounted for many consistent 2.2 second 60’ times on street tires, as well as dead consistent ETs.
I also find it VERY laughable that this guy thinks he has a change with even a stock SRT-4 let alone these other cars that "backed out".
LOL more like they saw what the competition was and decided not to waste the gas.
Yes, but you seem to have the wrong idea. I don’t drop clutch launch. I Slip the clutch out at that RPM in order to minimize wheel spin while keeping the engine in its power band (read: in VTEC).
Yea, make sure you get it from a roll so we know it’s not one of the many many many SRT4 lame-o drivers that manage to run a 15.8@103MPH
I mean, you want to fairly compare whos MACHINE is faster... right?
andohmygodthatsmilieistehh0m0!
yeah i am runnin the stock dunlop tires. Plz help me out on this. I am jetting 75, but dont know what to launch at and if i should dump the clutch or slowly launch then wot when i get traction? Also i was thinking about taking off my whole exhuast and running off the close coupled header/cat (vp dx lx) Would that be smart and help out?
Video is coming, I think my friends srt runs a little better than a stock srt even on low boost so with me right on his bumper I think it would be pretty close against a stock srt witha good driver..
