Urgent Gauge Cluster Swap Question Question
4 cyclinders down, 4 to go.....
I have searched the site and I haven't found a definitive answer-is it possible to swap gauges from an 01 into my 04 VP without rewiring? I really want plug and play. THanks
I dont think so man... you're gonna have to switch the pins out of the harness. There was a DIY to switch 01 to 04s awhile ago, im pretty sure you can just reverse the process... someone please link him to the DIY.
You will have to get the new cluster reflashed if you want the accurate mileage on it as well. Honda can do that, not sure how much though. They may want some sort of proof for original mileage??
from what i've heard 2001-2003 CLUSTERS can be swapped straight into 2004-2005 Civics.
The other way around is different (04-05 clusters into 01-03 cars) and requires rewiring since the newer clusters are more complex (?) or basically differently designed
click on link in sig to find pin diagram.
yeah i was going to put DX/VP since the member who posted a thread about it here on the site did it on his VP.
Dont really see why someone with an LX/EX 2004 or 2005 would wanna swap to the older cluster (it's plainer looking)
If you have a vp, it has the older style cluster. Any 01-02 cluster will swap without rewiring. The newer cluster with led and ring display will not work without rewiring. Only thing with swapping clusters is reflashing current mileage at a speedo shop.
i have an 04 vp also and what you guys are saying is that if i get an 01-03 ex guage cluster with tach and stuff. all i'll have to do is switch them out and have a shop switch the mileages?
2001/2002 clusters look like this -
(auto trans)
2003+ clusters look like this -
(manual trans)
all the lights/indicators (like the ABS, Maint Req'd, & SRS) should still work properly if you are downgrading from a ex to an lx cluster. You might have to reset them just once after installing the replacement cluster.
Resetting SRS light - http://www.7thgencivic.com/forums/sh...d.php?t=155251
Resetting Maint Req'd light - http://www.7thgencivic.com/forums/sh...d.php?t=174951
Resetting ABS light - should turn off after driving a bit, if the system in your car is working properly, if your car is equipped with ABS.
Extra info - When you are switching a DX/LX to an EX cluster, the ABS light will always stay lit because the cluster cant find the ABS in the car since the models dont have them.
(auto trans)
(manual trans)
Bruce.Ringler
Jun 18, 2015 08:12 AM
zaboomafoozarg
May 30, 2015 09:21 AM
Ma213802
May 18, 2015 07:01 AM
werdnahall
May 17, 2015 11:37 AM
Wish I had a Turbo
buy an automatic cluster (has PRNDd2 column) if you have an auto. buy a manual cluster if you have a stick
