low end power?
Old Jul 12, 2005
CIVIC X3's Avatar
CIVIC X3 is on a distinguished road
low end power?
i was wondering what mod is best to gain more torque on our vic...
Old Jul 12, 2005
CenZ's Avatar
PWIT
last time i asked they said bigger TB. so start boreing lol =)
Old Jul 12, 2005
K&N typhoon intake
kamikaze header
aem power steering pulley
sun hyper voltage system
keep stock exhaust
Old Jul 12, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
i thought intakes typically lowered low end..... i know that a pully will certainly work
Old Jul 12, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
you change your a/f ratio to bump torque. i know an lsd distributes said torque evenly so that would help. its my fav mod :-) but usually anything that bumps hp bumps tq too.
Old Jul 12, 2005
yea i gained 2wtq across the rpm band after fuel tuning. Also intake gave 2-8wtq and only 1whp.
Old Jul 12, 2005
CIVIC X3's Avatar
i was plannin on gettin a high output alternator, aem tru power pulley, and an optima battery to start...i heard that I/H/E doesnt give much power and its mostly for noise?
Old Jul 12, 2005
WhiteCastle's Avatar
I agree with gearbox, defently keep stop exhaust! however it suffers in higher rpms and freeway driving. You can tell major differnce between the two there
Old Jul 12, 2005
MajinB's Avatar
whats the point of the high output alternator?
Old Jul 12, 2005
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
the alternator isnt gonna give you power at the wheels, maybe if u have 5 15" subs @ 1000 watts each you'll need that.
Old Jul 12, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
he's prolly gonna get the higheroutput alt. so when he put the aem pulley on it and it slows it down, it's still does produces like a stock with a normal pulley or better
Old Jul 12, 2005
just curious has anyone actually ever wasted money to try and build an N/a powerhouse out of a d17?
Old Jul 12, 2005
CIVIC X3's Avatar
i was plannin to get a high output alt. not for power. cause i read in one of the thread that the pulley makes the light dim...so just getting it to power the lights. just gettin it like what booba saying...
Old Jul 12, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
i think that would draw just as much as a stock alternator without a pulley.
Old Jul 12, 2005
yea ho alternator will rob more hp from the engine.
Old Jul 12, 2005
mclean987's Avatar
mclean987 is an unknown quantity at this point
hey gearbox just a few qucik questions does the kamakaze header give alot more hp or tq than say a hp racing header? and how much hp if any does the hyper ground system give ? also why didnt you recommend crank pulley
Originally Posted by gearbox
K&N typhoon intake
kamikaze header
keep stock exhaust
Old Jul 12, 2005
crank pulley ruins motor. kamikaze I noticed more midrange than a generic ebay header. I believe it is equal length but I haven't measured the tubes yet. On an lx the kamikaze replaces the cat so thats even more gains. Just won't pass emissions. Hyper voltage system gives noticable improvement in throttle response. I took it off for a day and the car just didn't have the same pickup.
Old Jul 13, 2005
CIVIC X3's Avatar
where can i get the hyper voltage system? and is it easy to install or is there a DIY thread here?
Old Jul 13, 2005
hook one cable to positive battery terminal and the other to negative terminal. Two wires, thats it. i got mine from optauto.com and its the multirev MR version.
Old Jul 13, 2005
MajinB's Avatar
ok i plan to do an all motor d17 when my warranty runs out. i will tell you how it goes in a couple of years
Old Jul 13, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
Ok, great. I'll check back here in 2007.
Old Jul 14, 2005
mclean987's Avatar
wow thanks for that info, how does crank pulley ruin motor? what if its a balanced unorthodox?
Old Jul 14, 2005
http://www.7thgencivic.com/forums/sh...d.php?t=151653
Old Jul 15, 2005
CIVIC X3's Avatar
wow that some good info gear!...so the only pulley worth gettin is the aem tru power pulley and that's it right? or is there other ones you recommend? i know i'm diffinitely not gettin a damn crank pulley.
Old Jul 15, 2005
i wouldn't use the alternator pulley either, just aem power steering if you want to be safe. Replace stock crank pulley when you do timing belt cause it gets old too.
Old Jul 15, 2005
CIVIC X3's Avatar
is dere a prob with the aem tru power pulley too? cause i wanted to get it because i saw some guy on hear sayin it help with the throttle response w/a 1-2 hp gain.
Old Jul 15, 2005
my alternator died. the shop guy said the pulley was making it so the alt had to work non stop to keep charging the battery. So it died. The ps is a different system and pulley is okay for that.
Old Jul 17, 2005
mclean987's Avatar
damn i was gonna get a ho alternator i thought it would give power not take it, my friend put a gsr alternator on his b16 and he said it felt much better
Old Jan 11, 2006
Eclectic's Avatar
Eclectic is an unknown quantity at this point
K&N typhoon intake
kamikaze header
keep stock exhaust
just wondering gearbox, did you also get the hyper ground kit also? i was looking on that site where you said you got the voltage system and the description said that it's supposed to complement the hyper ground kit.
thanks
Old Jan 11, 2006
well i have upgraded ground wires yes. just replaced the factory ones with 4 gauge wire. theres a diy somewhere i did. i'm actually thinking about getting a different intake again lol. the weapon r one. i have to change my post tho. keep the stock header unless you have the engine ported. otherwise the holes are the same size so it won't matter gettin a different one.
