When my tires shakes......
Old Jan 28, 2002
HaRdKoRePinoYrAcer's Avatar
HaRdKoRePinoYrAcer is an unknown quantity at this point
I was wondering....when im going at high speeds like 90-100...my tires start to shake very bad....i have 16inch rims..and my friend told me they shake kuz there to small.....i was wondering....i been driving for a while now and i wanna know if it might have mess up anything?...how u know wut i mean....
in other words when my tires shakes very intense can it affect anything?....springs,the alinment,etc....thanx
Old Jan 28, 2002
trevor's Avatar
trevor is an unknown quantity at this point
Bigger rims.......thats the funiest thing ive ever heard,,,,,,,anyway,,,,,,,are they aftermaerktet wheels????
theyre probably off balance take em back to the shop and they should rebalance em for free
Old Jan 28, 2002
spoony's Avatar
spoony is an unknown quantity at this point
i would imagine it is alignment problem u really need to have that checked out
Old Jan 28, 2002
trevor's Avatar
if you have this new of a car you should worry bout alignement.........only unless you tagged a curb....which hopefully you havent
[IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jan 28, 2002
2k2civic's Avatar
Or you lowered the car or your if you tires are a smalled or bigger overall diameter. OR, if your wheels aren't properly balanced.
Old Jan 29, 2002
Jimmy24's Avatar
Jimmy24 is an unknown quantity at this point
You know what! I think the problem with aftermaket wheels is that the center of the wheel doesn't fit properly and it doesn't matter if they are ballanced, you'll still get vibration.
Do one thing, jack the car, remove the 4 bolts, once they are removed, check if the tire once in place, has play up and down, Factory tires once you push them in to the wheel lugs it just doesn't have any play 'cause the center hub fits perfectlly in the assembly, do you know what I mean?
What I'm trying to say is that the lugs primary objective is to hold the tire there.
the center hub's primary purpose is to keep the wheel where is supposed to!
Old Jan 29, 2002
GTekCiViC's Avatar
GTekCiViC is an unknown quantity at this point
if ur tire wobbles.......... u might of tighten your bolts on the rims too tight
try using a torque wrench to balance it out........ u should use 80 lbs of pressure.
Old Jan 29, 2002
trevor's Avatar
although if it was the hub it should shake at any speed.....
balance em.
[IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jan 29, 2002
Jimmy24's Avatar
Not necesarily, I used to have aftermaket wheels and they vibrate only at high speeds. If they vibrate at any speed, it might be really bad trust me!
Old Jan 29, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
if youve been driving like that for a while your tires will wear unevenly and faster than normal
Old Jan 29, 2002
mohawkboom's Avatar
I'm used to be a tire installer for quite awhile..
Your wheels are improperly balanced. a 15" wheel for example driving at 60MOH with it being say 25 grams off balance.(the little weights) Will be 13'bs so that's like having a 13'b weight flying up and down every time your wheel rotates. Not at 100MPH.. That's alot more weight which can make your wheels/whole car vibrate almost violently.... First thing I'd do is have someone drive behind you (at lower speeds) and see if the rims are bent in any way. Secondly. If that's not the case.. get em re-balanced. Aligmnet will NEVER cause a car to shake. It will cause a car to pull to either direction. It can cause stabily loss in turns. Or just plain ole Uneven tire wear.
Cheers
Mohawk
Old Jan 29, 2002
PerfectD3's Avatar
PerfectD3 is an unknown quantity at this point
[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]too small a tire[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]You friend is a crackhead[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Jan 29, 2002
yeh its prolly uneven tire wear...these rims are used...so im thinking of...putting my stock ones in after i take sum pix and post them in the rides.
Old Jan 30, 2002
Diznavis's Avatar
<< yeh its prolly uneven tire wear...these rims are used...so im thinking of...putting my stock ones in after i take sum pix and post them in the rides. >>
why put the pics in members rides with the rims and then take them off[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 31, 2002
b/c right now they look nice on them...the reason why im taking them off b/c im putting my stock tires back on b/c the donk shake!
twd000
Oct 4, 2015 12:52 PM
SidCivic
Oct 3, 2015 06:00 AM
siliconvalley
Sep 15, 2015 09:48 PM
alaga
25
Aug 13, 2015 04:42 PM
