Fuel Pressure Regulator Installation
Old Jul 2, 2005
Turbociv's Avatar
Turbociv has a little shameless behaviour in the past
Does anyone know where and how to install a n adjustable fuel pressure regualtor on the d17 civic's?
Old Apr 25, 2008
zxzkilme's Avatar
zxzkilme is an unknown quantity at this point
Re: Fuel Pressure Regulator Installation
i asked the same question...
Old Apr 25, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
We have a returnless system fuel system........which means....the fuel pressure regulator is in the fuel tank....all fuel flow is controlled by ECM.....
The return style system pushes all the fuel it can and then the regulator decides what to use........we need to convert over to a return style to proper control this.
You need a boost sensing regulator, modified stock fuel rail w/ return bung, alot of SS hose back to tank, & a good fuel pump
Old Apr 25, 2008
army12bc's Avatar
army12bc will become famous soon enough
i bought a bdl fuel rail and aem regulator and the shop i went to said that they could do it without all that cause the regulator is on the rail. i just need to get the -an fittings to convert the lines.
Old Apr 25, 2008
what happened to that vendor that used to sell the full return fuel conversion?
Old Apr 26, 2008
FoSho's Avatar
Well I don't know what shop can do fuel rail swap that easy.....good luck with that, they must be magicians!
Dopes was able to mock up a boost sensing regulator setup w/ his stock pump & FPR.....I believe he was able to go 15psi +........he has a write up on it.
I believe streetlevelperformance still sells the kit for this but it's crazy money.
I belive 600-800 dollar range.
This is too easy of a setup to build for that much.
-Bulk supply of SS line
-AN fittings & weld on bung for stock fuel rail
-Modified Stock fuel rail
-Upgraded fuel Pump
-Boost sensing FPR
-& the ***** to hack up your stock pump.....
I think the hardest part of your day would be messing with the -AN fittings.....SS lines in the freezer overnight. I been doing that for years & it works great. You don't even have to buy -AN wrenchs. My Snap on Wrenchs are so smooth they don't scratch my fittings!
Cake walk......
Old Apr 26, 2008
HwNpRyDe_CiViC's Avatar
HwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura about
summitracing.com has a complete kit ..
http://store.summitracing.com/partde...5&autoview=sku
then you just need a couple more -an fittings for things such as fuel pump mod and stock fuel rail modding to ad a nipple.
here is teh fuel pump mod and a diy for the return fuel conversion-
http://www.teamxxxracing.com/Forum/s...p?t=745&page=6
http://forums.clubrsx.com/showthread...walbro+install
then search clubrsx for the walbro mod to make it a return system fuel pump.add you fpr and your all set my friend!!! my install will be happening next weekend. ill take pics and make a diy.not to bad i got all my stuff from summit for 150 bucks.a bnib weapon r fpr for 25 deals*super deal* hahaha and i bought my walbro 255 awhile back for 85-90 bucks i believe..
Old Apr 26, 2008
when you search clubrsx for the diy for the walbro 255 look for the thread started by palmerblock!!!!
Old Apr 26, 2008
FoSho's Avatar
A Link please? I don't seem to be able to find it....
Old Apr 26, 2008
http://forums.clubrsx.com/showthread...rn+fuel+system
Old Apr 29, 2008
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
I've got an SLP return fuel kit I'm trying to sell (along with a turbo...my car modding days are over now that i'm married and settling...hah) i'm not too far from WV depending where you are. I can help with the install if you're willing to swap parts
Old Apr 30, 2008
FoSho's Avatar
Mex, how much you looking for that SLP kit?
Old Apr 30, 2008
Mex's Avatar
Mex
well, I was hoping to do a part swap locally for $100 (swap including the turbo for $1,000)... I'd probably be willing to ship for $180.
Old Apr 30, 2008
FoSho's Avatar
got any pictures....what all does the kit include?
Old Apr 30, 2008
i remember that from back in the day. it has everything, quality kit.
http://streetlevelperformance.com/Ho...ion%20Kit.aspx
Old Apr 30, 2008
FoSho's Avatar
If that kit comes with everything in that link deal son! Hit me up with some pictures & paypaL! Will have cash to ya tonight!
I didn't jump fast enough on that KMS intake manifold damnit!!! Gotta get on something.
Old May 1, 2008
Mex's Avatar
Mex
here are the pictures:
I've had the kit for about 3 years now, but never got to take full functionality with it due to turbo complications. The one thing I didn't like about the kit was the lack of a secure mounting into the fuel tank... what you see in that picture is a load of gorilla glue (which worked ugly, but never had problems since day one). A little R&D on someone's part and a better installation option can be made using custom brackets or whatever... it's just dumping the fuel returning from the engine back into the tank.
The kit also came with the wrong sizes of Earl's Super Stock Fuel Hose, so rather than wait (installation was already under way before discovering this...) i went out and bought fuel-grade hose.
Nor did it come with instructions, but I'd be happy to help with any questions and can take pictures of how it's installed as I disassemble it.
I ordered the stock parts needed to uninstall and it came to just under $100, but I was really hoping to make at least $100 off this, so does $200 sound ok, with shipping on me?
Old May 1, 2008
FoSho's Avatar
Sweet...so I get...
Aeromotive Boost Referencing Fuel Pressure Regulator
B&M Fuel Pressure Gauge Kit
Walbro 255lph Fuel Pump
SLP Modified Fuel Rail
Stainless Steel Braided Fuel Lines (Cut to exact measurements - I guess not huh? haha)
High Quality Fittings (Pre-Installed in lines)
Detailed step by step instructions(well your pictures & help! haha)
-Do you not have the fuel gauge kit installed?
-That price also includes walbro pump?
-FPR still holdin up good after 3 yrs?
-What were you tuned on?
-Plug & play install....or....did it require tuning modification?
Correct? 200 shipped? Send me your paypal immediately!
Old May 1, 2008
Mex's Avatar
Mex
The stainless steel fuel lines are fine and cut to spec, but the Earl's Super Stock Fuel Hose was not. I no longer have that... it was probably cut to shreds in frustration. They were only two hoses, cut to less than a foot each. The ones I received were just inches too short. I'll be sending the one's I'm currently using.
I didn't need the fuel gauge kit because i had an autometer cobalt gauge already. I still have the B&M gauge kit to ship though (which is really just a B&M gauge with fittings attached to fit into the regulator...good for engine tuning, but you'll need extra line to feed it into the cabin to install...).
The walbro pump is still in my tank and will be removed for shipping.
Haven't had any issues with the regulator crapping out...pressure has been consistent to what i have it set at (45psi). Once you step on the gas it goes up about 7-8psi, but I've never tested it under high boost (only had mine set around 3psi due to lack of e-manage/tuning).
The install is almost plug & play...you'll need to drill a hole in the top of the fuel pump assembly to get the return line fitting screwed in and drill holes to attach the regulator onto the firewall, otherwise pretty straight forward. Pressure is managed using a hex wrench (I think turning clockwise raises the pressure). I initially had problems because I forgot to remove the stock regulator in the tank, thanks to not having installation instructions. You won't make that mistake
my paypal e-mail is stever703@comcast.net - I'm hoping to have all the parts I need no later than next weekend to get this shipped out to you. I'm guessing you're not close to DC, cause I'd be happy to help you with any assistance you need!
Old Jul 3, 2008
Mex's Avatar
Mex
bump.. any takers on this SLP kit? I'll ship it for $150... need to get this kit out of the house. Read above for kit details...
Old Jul 4, 2008
speedfoos's Avatar
Hmm...good kit. I know I paid more for my return setup after piecing it together individually. You other boosted guys (emjay!) should jump on this!
Old Jul 4, 2008
emjay's Avatar
emjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the rough
omg i jus saw this thread and if it wasn't for foos i wouldve never seen it .. thanks for the bump .. Mex .. paypal .. sending money right now ! fosho had 3 months to buy it so u best be showing me some interest lol .. so mex .. what exactly do i need on top of what ur sending me to install this kit ? ... the fuel rail is modified already.. ur including all SS lines, fuel pr, bnm gauge DOES this mount on the regulator under the hood? similar to the AEM fuel pressure regulator?? whould i replace the FPR with an aem one ? hmm seems too complete ..
wats the condition .. 3yrs, wear? tear? still a quality kit .. im going for 300whp so i need something quality , what would u change baout the setup ? if nothing then im game bro im serious ..
Old Jul 4, 2008
emjay's Avatar
Old Jul 4, 2008
emjay's Avatar
hmmm ... question .. foos or anyone-- i jus called my machine shop and he said since im going with the d16 intake mani .. he is going to swap the rail too and the rail on his shop has the return and everything on it so he's like there's no point in returning ur d17... My question was will the d16 fuel rail fit my d17?? .. will i have any problems or with simple mods he can replace my IM, fuel rail and TB with the d16?
Old Jul 4, 2008
speedfoos's Avatar
Whoa stop. You ask like 15 questions in two sentences! If your new rail already has an FPR, you will just need to run a new line to the tank into a bulkhead fitting to run as the return. Check clubrsx for a couple good DIYs on to do this.
So. Yes, the D16 rail will fit your car because you're converting to a D16 intake mani. Heck, a D16 rail fits a D17 intake mani (from what I remember), you just need to run the return line. Since you've already got the stuff (STR rail and FPR), you don't really need this setup unless you don't already have the fuel line and the Walbro pump.
Old Jul 4, 2008
emjay's Avatar
lol foos sorry bout my questions u got me so excited about this return setup haha .. ok well i have the walbro fuel pump already .. i don't have any lines tho
Old Jul 4, 2008
andyman97's Avatar
Turbo Guru
Wow, the fuel pressure isn't controlled by the ecu, it's a purely mechanical system. There is a regulator in the in tank pump assembly with a spring that needs to be removed. You don't have to modify the rail. All you need is a T in the feed line before the rail, one goes into the side of the regulator, the other goes to the rail. Then drop it off back to the tank. It's relatively simple.
Old Sep 1, 2008
Mex's Avatar
Mex
Bump... still have the above mentioned SLP return fuel kit above for sale! please PM me if interested. Pics are also above!
Old Sep 2, 2008
army12bc's Avatar
pm sent
Old Sep 7, 2008
army12bc's Avatar
Mex i can't message you it says its full i need the directions for that kit i got sat. i'm confused on the entry line setup
