A/C Problem
Hey guyz.
Here's a question about my AC, if anyone could help.
(Thanks in advance just for reading)
2001 Civic EX 4 Door
When I turn on my AC, it does some pretty weird things. The AC keeps clicking on and off; the clicking is violent, also. My RPMs drop as if I was gonna stall, then the engine revs up to prevent the stall. Sometimes it works, sometimes it doesn't. Under the hood: When the violent clicking occurs, one of the cooling fans turns on, then it clicks and the fan turns off.
Any ideas?
I need one
Any ideas?
I need one
I Hunt Goats, Rams, And Mustangs.
Your copressor is proabbaly not kicking on, *locked up, or starting to lock up* does it look like the compressor pully kicks on when the ac comes on? or does it just slowly turn or not at all?
everything you said is normal. Except if the car actually stalls when you turn the ac on. then there's a problem with an idle control device.
ALGARETE
Originally Posted by C2FDI
Hey guyz.
Any ideas?
I need one
Any ideas?
I need one
Thanks for the responses, fellaz...
But the problem is, this happens CONSTANTLY...It doesn't just happen once or twice. It will click on and off on and off, sometimes only blowing warm air, something blowing cold air. This will go on for hours. My RPM's are dropping constantly.
I think I might have to take it to a mechanic. I hate people touching my car. Any more words of wisdom from my Civic friends? Honda wants $89 just to LOOK AT IT. I WILL WALK BURN THE PLACE DOWN BEFORE I PAY THAT MUCH JUST TO LOOK AT IT. TO HELL WITH ALL OF THEM.
I have had two vehicles that have had a similar problem with the rapid engaging and dis-engaging of the AC Compressor Clutch. The solution for both was to pick up a can of R-134a AC recharge from the auto store and re-fill the system. When i checked the pressure in the system with the gauge that came with the refill can, it showed that I had nothing left in the system. I added 1 full can (maybe 10-12 oz) and the problem stopped and the AC was good and cold.
Just remember not to overfill the system. It is normal for the compressor to turn on and off but not constantly. The recharge can cost me 8 or 10 bucks and now I have a guage i can always use to check, so I think that is a good place to start. Hope this helps!
i wouldnt do that, itll lower the temp/pressure.
goin back to ur problem w/ cuttin on and off... its prolly not enuff freon in it. itll cause to freeze up the core and cause the compressor to kick on and off due to high pressure build up.
your best bet is to get a readin on both side of the pressure.
Originally Posted by njerry
try letting a little pressure out of the low pressure hose, you know the one that is marked with a big "L" on it.
the reason I say that is, because my a/c was going thru the same problem, and by releasing a little pressure that seen to help out eith the problem.
its a leak....
You have a leak somewhere in your system. Could be something easy like a freon line or something worse like the compressor. Ususlly when the compressor continually clicks on and off it means that you are low on freon and eventually your system will freeze up if it continues running that way. I would not recommend buying that freon in a can from the auto parts store. Many people have used that and overcharged their system which results in permanent damage to the compressor or the evaperator. It is also illegal to release freon into the environment, you need a recovery device which is very expensive so don't bleed freon yourself. Take it to a reputable shop, not Honda, and let them do a pressure test for you to check for leaks and see what the damage is. They can either use an electronic leak detector which works fine on larger leaks or inject a fluorescent dye into the freon line and wait to see where the freon is coming out. I work on AC's in homes for a living in Florida so I have seen it all. It sucks not having AC in this heat. Good luck and let us know if you need more help.
Drunken Master-7thgen Ninja
im sorry but i can't stress this one enough. 100k warranty. if you have it, they charge you nothing. if you don't go to a mechanic thats not from honda and watch the labor price get much better.
Originally Posted by CIVIC808
it is most likely you are low on refrigerant.the low pressure switch will knock it off when the compressor runs.when the compressor turns off, pressure rises,thus making the compressor run again and so on. your best bet is to let a technician handle it or someone who is familiar with a/c systems.
yes i have a 100k warranty on my vic. i bought the car 5 months ago. its an 01 that had 56 k on it. its like 64 now. anyway, yes i have it, and it has already come to use. my srs light was replaced at no charge. anyway, why are you suprised?
Originally Posted by DaCurryman
100k warranty on a Civic?!
Thanks EVERYONE for your input, very useful!
Here's the status:
I took it to a service station, spent $120 to get my freon flushed and refilled with Honda's. Problem still happens. I have an appt. Thurs. to see what the problem is, but regarding this post::::
Sounds like you know your ****. When they flushed the system, they also put the dye in it, so they are gonna be able to check to see where the leak is (if there is one).
But let me add some confusion to this mess...My AC works like 80% of the time, it's when I come to a stop/idle that there is always a problem. That's when the condenser clicks on and off "violently"....Could a leak still be suspect?!? *$&#'ing Honda....
Here's the status:
this might help
http://www.4s.com/fourseasons/tech_t...ish/ab303.html
mikemc422
Aug 9, 2018 05:41 PM
g4384063
May 30, 2015 11:21 AM
dinsum
May 28, 2015 09:30 PM
beveragemp
May 25, 2015 07:11 PM
