brake pads????????????
Old Jan 26, 2002
hose2k1's Avatar
hose2k1 is an unknown quantity at this point
yo! wat up 2k1 civic owners listen my question is for the brake pads. mine will be wearing out shortly and i would like to know if any aftermarket brake pads out there are sold to help your car brake better with out having to change rotor and that other stuff. instead of installing those stock ones im intrested in installing some stronger and more durable pads[IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG] i mopen for opinions ??????and links and diy
Old Jan 26, 2002
mohawkboom's Avatar
AEM/Nissin pads...
Cheers
Mohawk
Old Jan 26, 2002
Grey's Avatar
DIY King
Check out my DIY. I just finished today. DIY: Rotor and Brake Pad Install
Old Jan 26, 2002
drbombay's Avatar
drbombay is an unknown quantity at this point
you guys are going through brakes fast.
Old Jan 27, 2002
joe's Avatar
joe
joe is an unknown quantity at this point
yeah ive gone trough three sets of brake pads in less than a year. [IMG]i/expressions/face-icon-small-mad.gif[/IMG] next time ill get the aem brake pads and hopefully theyll last longer.
Old Jan 27, 2002
Grey's Avatar
DIY King
Are you breaking in your brakes properly after changing the pads?
Old Jan 27, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
how do you break in the new pads?
Old Jan 27, 2002
Grey's Avatar
DIY King
Link Numero Uno
Link Numero Dos
Try those two links. They tell you a little bit about rotor seasoning and pad burnishing. [IMG]i/expressions/beer_yum.gif[/IMG]
Old Jan 28, 2002
Jimmy24's Avatar
Jimmy24 is an unknown quantity at this point
Hey Grey, I don't know how true this is but I think somebody told me that this procedures were good for cars w/out ABS.
For car with ABS, I was told that it was bad for the ABS system to just push the calipers back were they where. I was told with ABS you were supposed to open that small bleed valve and then, use the caliper to push the piston back. So then you bleed the system. But I don't know how true that was, I did it your way anyway, 'cause I wasn't goin' to bleed nothing. But really, I either read it or somebody told me. I just hope I didn't F*ck anything up![IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Jan 28, 2002
Grey's Avatar
DIY King
I don't know ABS would have to do with pushing the piston back? ABS is just a control system for the brakes. It has a different master cylinder and it pumps the brakes very rapidly.
The only reason to push the piston back like you said it to fit new brake pads in because the new brake pads will stick out more than the old ones. You have to open the bleed valve to push the piston in because fluid doesn't compress easily. After that you don't necessarily have to bleed your brakes. Just pump your brakes a few times to seat the brake pads on the rotors and top of the reserve tank of brake fluid. Easy as cake! Piece of pie! [IMG]i/expressions/laugh2.gif[/IMG]
Old Jan 28, 2002
Jimmy24's Avatar
The thing is that I never use that bleed valve and I want to know if I'm F@@ing something up!
Old Jan 28, 2002
Grey's Avatar
DIY King
I don't think so. I'm not an expert though. I didn't and my brakes seem fine. I'm still breaking them in though, so I'll know for sure if everything is tip top shape after I have broken them in.
Old Jan 28, 2002
Blk4blk2K1's Avatar
Retired Super Mod and STILL Pimpin' Yo Mama
Blk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to behold
Wow, 3 sets of pads in less than a year?! You ridin those things or what..
Old Jan 29, 2002
Jimmy24's Avatar
Hey Grey, I know you said to apply some grease or something on the back of the brake pads but, what's that for! are you talking about this little gray bag that comes with the brakes? Because I didn't know what was that for, still don't know and I never used it. Anyway, there is no instructions in the box. BTW thanks for the info always, I apreciate it man!
Old Jan 29, 2002
Grey's Avatar
DIY King
Oh yeah, the grease is anti-squeel grease. It helps to seat the brake pad in the caliper, helps it slide freely and prevents annoying squeels. Just put it on the back side of both pads and on the top and bottom tabs that slide into the copper slides. DO NOT put any on the area of the pad that touches the rotor. Also, there are these slip covers for the pads. Put the grease betwean the slip cover and the pad and betwean the slip cover and the caliper. Weird thing was that I only had one of these slip covers on each side, while the illustration on www.hondaautomotiveparts.com shows two of them?
Old Jan 29, 2002
Jimmy24's Avatar
Thanks man! i apreciatte it
Old Aug 15, 2002
SilverTrouble's Avatar
SilverTrouble is an unknown quantity at this point
[IMG]i/expressions/face-icon-small-blush.gif[/IMG]
Just changed the pads today - 33k miles[IMG]i/expressions/face-icon-small-puke.gif[/IMG][IMG]i/expressions/face-icon-small-puke.gif[/IMG]
bought OEM from manchesterhonda.com - $35
old ones were not that bad but the brakes used to make weird noise....
Old Aug 15, 2002
Grey's Avatar
DIY King
BTW, if anyone else wants OEM pads, then I have some for SALE! Only $30 shipped.
cncnut
Aug 23, 2015 01:25 PM
honda.lioness
Aug 6, 2015 11:58 AM
Strycker
Aug 2, 2015 08:40 PM
DerbyDad03
Jul 27, 2015 11:34 AM
General 7th Gen
Jul 9, 2015 10:17 PM
