Brake vibration
Old Jun 16, 2005
flqu05's Avatar
flqu05 is an unknown quantity at this point
Brake vibration
I feel it most coming to a stop from a high speed. Im guessing that the rotorss may bve warped and need replaced? I doubt resurfacing would help?
Old Jun 16, 2005
tfnaaf's Avatar
BLDNPSI Mod
resurface if they are thick enough
Old Jun 16, 2005
PunkingCivic's Avatar
I need TP for my bunghole
^^^what he said^^^
take it to sears for a brake inspection
it is $15 dollars
and if you need work done
the $15 goes toward the work and parts.
Old Jun 16, 2005
01redJDM's Avatar
01redJDM is on a distinguished road
I have exact same problem with my brakes, help plz
Old Jun 16, 2005
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
get some brembo($30 ea.) and new axxis pads($65 pr.). You will not regret it. i love it.
Old Jun 17, 2005
streetglower's Avatar
Originally Posted by PunkingCivic
^^^what he said^^^
it is $15 dollars
why go to sears and have to pay when most independent shops now days have free brake inspections.
Old Jun 18, 2005
Bigfella's Avatar
Bigfella is an unknown quantity at this point
Are the Brembo's a straight swap, or are you talking big brake conversion here. Just want some quality discs that are not grooved or drilled, same as standard. My coupe has the same symptoms and it only got 29k on clock and is still on original tires, so it cant have been driven that hard before i got it. No vibration at steady speeds, but slowing down from about 80mph+ it feels like there warped.
Old Jun 18, 2005
R1Style's Avatar
brake rotors are warped... get them replaced or remachined.
Old Jun 18, 2005
flqu05's Avatar
20 k miles? Waranty??
Old Jun 18, 2005
brakes are covered under warranty
Old Jun 18, 2005
Bires's Avatar
Bires is an unknown quantity at this point
Uhm...since nobody mentioned it, do you have ABS?
If so, your rotors and pads/shoes may be fine, but your ABS may be engaging early and need to be adjusted.
Old Jun 18, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Brakes are not under warranty.
Regardless, if you can get a free inspection of them, have at it, but if they have to be pulled you're gonna get charged. And its not worth turning the rotors (new ones can be bought from autozone for $19.11 each, its about 10-15/ea to get the old ones resurfaced. And there's nothing wrong with the cheapo rotors. A stock sized rotor is a rotor is a rotor. They're all the same straight veined vented disc.
Old Jun 20, 2005
Yes. Straight swap.
Old Jun 20, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
ok first of all, do you drive a stick? if so do you ever down shift to slow down? you just might be over using your brakes. yes a such thing exists. how bad is the vibration? does your steering wheel shake? what exactly is vibrating? help me picture this problem, and ill try to help you out as much as i can. could be your abs controller. how long have you had the car and have you ever had the brakes done before. how many miles? help me out. thanx
Old Jun 20, 2005
gotarheels03's Avatar
gotarheels03 is an unknown quantity at this point
I have a similar problem with my 04, 11K miles. If I hit the brakes going 60-65+ I get bad steering wheel shake. At slower speeds I have nothing, even under hard braking.
Old Jun 20, 2005
Big Rob's Avatar
I'm taking over!
Big Rob has a little shameless behaviour in the past
Mine did that to. That is no big deal. At my dealer it is one of the things that is fixed when you get a brake job. It is pretty common with our cars, and it is also easily fixable. The problem is warped rotors. Usually they just get clipped or straightened. It costed me around $60 at the dealer for the entire brake job, and like I said, that is included. After the job, I didn't have any more trouble with that.
On a side note, the noise that it makes does sound kind of cool doesn't it?
cncnut
Aug 23, 2015 01:25 PM
GritzNGravy
Aug 19, 2015 03:03 AM
Low_Lupe
Aug 17, 2015 10:57 AM
alaga
25
Aug 13, 2015 04:42 PM
honda.lioness
Aug 6, 2015 11:58 AM
