2005 Civic - Odometer Stopped ...
Old Jun 12, 2005
birdman-c's Avatar
birdman-c is an unknown quantity at this point
So heres the deal. I was hardwiring my Valentine One today. For whatever reason, I ended up blowing a fuse. It is the "Meter" Fuse which is on the far right hand corner of the fuse panel under the steering wheel.
When the fuse was blown, the car had approximatley 8000 clicks. With the blown fuse, the gas gage, spedo and tach all did not work...
I drove the car approximatley 500 KM's until replacing the fuse. When I plugged it back in, the Odometer still reads the reading from when the fuse blew. It is possible that I can get the real meter reading using an OBD-II scanner?
Also - I noticed the Air Condition did not work with the meter fuse blown. Well, sometimes it does, sometimes it doesn't. Usually goes on for 10 seconds when you start the car, then the AC shuts itself off even though it is turned on it the cockpit.
Can anyone comment?
Old Jun 12, 2005
S2000man01's Avatar
O RLY
no. your odometer now is technically "faulty" and reading not the true mileage.
when you blew that fuse, it basically prevented the speed sensor wire from transmitting to the ECU. the speed sensor wire controls your odometers, and your speedometer. obviously this also affected whatever sensor readings were sent to the gas and tach as well. the AC i dont know.
basically because you drove the car in this condition, the car's ECU and odometer thought the car was never moving. however, there are other sensors that may have given a clue to your ECU that the car was moving.
i'm somewhat surprised you didn't get a check engine light. i'm guessing, however, that you do not have an EX with ABS.
either way, i'm not aware if the civic had any other way of knowing the car was moving. if it did, you should hope the ECU did not record the fact that your odometer/speedo wire was cut/inactive while the car was moving. you could get into some trouble if it did, and the dealership or anyone finds out. if you or anyone ever has this happen, DO NOT DRIVE THE CAR until you get the problem fixed.
Old Jun 12, 2005
jttegx's Avatar
OMNES AD UNUM
sounds like a very serious issue. i would bring it to honda/pros asap.
stash the rader detector and make it seem like it just happened out of no where. show up and try to make yourself look unknowlegdeable to cars as most as possible. try to say random stupid things as well like "my miles dont go up"
Old Jun 12, 2005
S2000man01's Avatar
O RLY
another thing. i doubt your problem was caused by a blown fuse.
the speed sensor wire as far as i know, does not go through a fuse panel anywhere. i'd need to see a helms manual to know for sure, but most cars have the VSS or vehicle speed sensor attached to the drive shaft or transmission output shaft in some way or another. the wires then run up through various harnesses directly to the ECU.
so no combination of fuses blown should cause your ECU's odometer to stop reading your mileage. i think you may have pulled a wire loose somewhere.
this is my educated guess.
Old Jun 12, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
it was just a fuse. i have done it b4. you pull the fuse out and all your gauges go and cel or maint reqd lights turn off also your a/c wont get cold. but if you turn on your head lights your a/c will turn cold again. it is just a fuse the dealership told me thats all it was when they looked at mine.
Old Jun 12, 2005
S2000man01's Avatar
O RLY
this would be the first time i've ever known a VSS on a car to be wired to a fuse of any kind and then to the ECU..... for this exact reason. you could simply pull the fuse and stop your odometer to prevent it from recording mileage.
Old Jun 13, 2005
Logan3024's Avatar
i agree honda would never let stopping the milage be as easy as removing a fuse. If it was that easy i would have done it along time ago
Old Jun 13, 2005
birdman-c's Avatar
Well, I am thinking now it is that easy.
Like nick95763 - I tried turning on the lights and now my AC does get cold. I assume the ECU is showing the correct mileage, but yes - if the fuse is pulled the odometer does not add miles.
Old Jun 13, 2005
flotsamm's Avatar
I'm guessing the VSS goes straight to the ECU, then the ECU talks to the odo via a fuse. If the fuse is blown, whatever that fuse protects wont work..
Old Jun 13, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
Do u know what this means? we can rip off the entire world HAHAHA!
Old Jun 13, 2005
birdman-c's Avatar
Well, my main concern is that I plan on selling this car in two years. I am not a crook so I want the official mileage to be reported on the ODO.
At this point it does not need possible to "add back" what has already been missed. If I go and turn in the car, will the dealer know this has happened and mark my car as a salvage title because the Odometer is not correct? That would basically render the car as worthless.
Old Jun 13, 2005
Jrfish007's Avatar
Have you tried resetting the ECU yet?
Old Jun 13, 2005
birdman-c's Avatar
No, I haven't tried to reset anything. How would I do that?
More importantly, I would like to get the correct odometer reading out of the ECU if that is possible.
Old Jun 13, 2005
Jrfish007's Avatar
Disconnect your battery for about 5-10 minutes. If your speed cable IS connected directly to the ECU, that MIGHT bring the milage on the ECU (that correct milage if all the assumptions are correct), but I'm not sure. Hope fully it will reset the odometer. In any case, it won't hurt and doesn't cost anything.
Old Jun 13, 2005
S2000man01's Avatar
O RLY
Correct me if I'm wrong, but don't the civics have a digital display gauge for the odometer?
If that's the case, then any mileage stored in the ECU would be displayed automatically on the odometer. The odometer is nothing more than a display for what the ECU knows the mileage to be. Even if you cut the wire to your odometer, and then 1000 miles later reconnected it, the odometer would STILL display that extra 1000 miles.
If they have an analog display for the odometer, then yes, the ECU will have the actual mileage recorded, and that will be known if the dealership ever queries the ECU. Which means they will then know the odometer is displaying false information.
Your best bet is to go to a dealership and tell them you suddenly noticed your odometer seemed to stop working. Remove the valentine and hope they don't find any evidence of tampering, otherwise you're screwed.
Old Jun 13, 2005
PlasmaGT's Avatar
My Baby Daddy
PlasmaGT is on a distinguished road
I thought that the mileage was kept in the cluster. Not the ECU.
Old Jun 13, 2005
Al Gore FTW's Avatar
jdmtytedoridori
the civics DO have a digital odo reading, but if you unplug it for example, then drive 10 miles, and plug it back in, it displays the cars actual mileage, less 10 miles. so basically it doesn't change. like in my car, i swapped stock gauges for rsx gauges at 31094 actual miles, and the rsx cluster had 35564 miles on it, so my mileage reads 4470 miles above actual mileage on the car.
Old Jun 13, 2005
Jrfish007's Avatar
Yeah... my thoguht is that maybe the display freezes to show that something has gone wrong. So resetting everything might clear that up. And if it doesn't take it to the dealer and tell them some a**hole on the internet told me to take the battery off for a few minutes.
Old Jun 13, 2005
nick95673's Avatar
my thought is that sometimes things dont get thought out. and this is one of them. why would the gauge hold the numbers even after you have them in your closet for a year if the milage was stored in the ecu. o yeah honda has a ton of small memory cards they need to get rid of that they love to place in their ecu and gauges.
Old Jun 13, 2005
birdman-c's Avatar
Ok, I disconnected my battery for 10 minutes to reset the ECU. Put it back on, ODO still shows the incorrect mileage reading (less).
My guess is that the ECU doesn't count the miles at this point...
Old Jun 13, 2005
CraigW's Avatar
On the Toyota Corollas the cluster swap from CE to LE was a popular mod. On those the original speedometer/odometer section could be removed and installed in the LE gauge to keep the original mileage reading. There is a circuit board that counts speed sensor pulses and increments odometer. I would imagine this is made similar, I would not sweat the slight difference in readings.
Did the A/C work O.K. after fuse replacement ??
Old Jun 13, 2005
nick95673's Avatar
yes once you replace the fuse and aslong as w/e blew the fuse is fixed everything works the way it should
Old Jun 13, 2005
S2000man01's Avatar
O RLY
i found a rough electrical schematic for the civic.
VSS is uninterrupted to the ECU.
odometer mileage is stored in a memory module that is within the gauge cluster, NOT on the ECU. so resetting the ECU won't do squat.
the only way to get it fixed is to take it to honda and have them manual adjust the odometer. if the car is under warranty, just tell them your clusters went out one day when you turned on the AC. you found the cause was a fuse and replaced the fuse, but the mileage was not added on and you need them to fix the mileage.
remove any and all evidence of you installing the radar detector first.
Old Jun 13, 2005
nick95673's Avatar
so what your saying is if we put a switch on that fuse we can set our cruise control and turn off our odometer and never be caught unless we are caught red handed.
Old Jun 13, 2005
birdman-c's Avatar
CraigW - After fuse replacement A/C works 100% normal.
Old Jun 13, 2005
birdman-c's Avatar
S2000man01
I was told by a honda mechanic today that the ECU does not store mileage... I brought it to the dealership today to ask them to reset the mileage, and the people basically laughed at me and said "your lucky... leave it as it".
I guess honestly is laughed at these days...
Old Jun 14, 2005
Jrfish007's Avatar
S2000man01
wow... that's something. You could try to replace it your self, but I wouldn't, I would probably go to a different dealer. On the other hand if Honda finds out it went bad, they may mark your car is not having real milage, and that will make it very hard to sell. If you just fix it your self, no one would ever know and the car will sell fine.
Old Jun 14, 2005
flotsamm's Avatar
Some dealers when they install a new odo or cluster they'll place a sticker on the door jamb that shows the adjusted mileage... shouldnt be a big deal.
Old Jun 14, 2005
S2000man01's Avatar
O RLY
yup, if the dealership can't adjust the odometer, they put the sticker on the door jamb.
Old Jun 14, 2005
S2000man01's Avatar
O RLY
S2000man01
yes i already said that a few posts ago.
