Audio deck got drenched in Sprite!
Old Jun 1, 2005
silver04coupe's Avatar
silver04coupe is an unknown quantity at this point
My friend and I were taking shots of Candian Mist and chasing them with a 2 liter bottle of Sprite and when I was chasing my shot he hit the bottle and Sprite got on me. I didn't say a word and just pretended that it didn't happen. So when he chased his shot, I hit the bottle up even more and he got completely drenched all over his face and shirt. A split second after that he grabbed the bottle and out of instinct he sprayed it all over my dash and mainly my stock audio deck . Now when ever I turn the stereo on, all you hear is one loud tone of deep bass (I have two 12" subs) even if the volume is all the way down.
Now I need to find out how to remove my deck to put in my old cassette deck and use a CD walkman to play CDs. Can somebody tell me how to do this?
Old Jun 1, 2005
BassKadett's Avatar
BassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to all
Use this
That sucks bad! Now take your ruined deck and shove up your retarded friend's ***.
Old Jun 1, 2005
doubledeuce2k2's Avatar
04+ are more difficult, different from that link, although it's a start. look in the ICE forum and you'll get help there.
Old Jun 1, 2005
BassKadett's Avatar
^^I wasn't aware of that. Thank you.
Old Jun 1, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Eh.... I can probably fix that deck. You have to wash it out with hot water and dry it for 24 hours. An air compressor helps there. Everything BUT the CD drive. That has to be done seperately. Sprite is conductive, that's why it acts up. I've done it before, no biggie.
Old Jun 2, 2005
Thanks but I still need to find out how to remove the damn thing. I know there is a DIY but thats for an automatic. So then I tried to remove the entire console but I stripped a screw severely and now I'm "screwed". I stripped the arm rest hinge's screw. Is there still hope? Can I still remove the deck?
Old Jun 2, 2005
02blackcivic's Avatar
02blackcivic is an unknown quantity at this point
in my car when i turn my stock headunit, i hear a loud bass noise from my subs, very loud, is it cuz my car is still sending power to my subs, not trying to ***** your thread, but i thought i was the only 1 with this problem, although i didnt spill sprite in my headunit
Old Jun 2, 2005
Can somebody give me a DIY on how to wash out my deck?
Old Jun 3, 2005
tinman's Avatar
If you can take the deck out, and then take it apart, remove the cd mechanism. It's held on by only a few screws and then unplugs. Then wash out the radio with water. You need water because soda has a lot of sugar and water will disolve it easely. Use a small brush to get everything clean. Then blow it out with canned air or best an aircompressor. Let it dry in the sun for a day. Put the CD drive back in and test it. It should work fine.
You may have to take apart the face plate to clean behind it as well. You can use warm water with a few drops of dishwashing soap to brush everything off. Rinse well. Remember that water won't hurt electronics if: A) It doesn't sit on parts for days, and B) you make sure everything is completely dry before you plug it back in.
The exceptions are speakers and VU meters or analog meters of any kind. Those must be removed before washing.
It is not uncommon to wash circuit boards. Don't be afraid to do it as long as you are careful to let it properly dry.
Old Jun 3, 2005
exturbo6's Avatar
well its easy to take the head unit out. ive done it like 4 times on my 7thgen. not hard at all. and like what basskadett said, shove it up your friends ***.
Old Jun 6, 2005
Thanks for the DIY but I still can't remove my deck. When I lift up the console that surrounds my shifter, it doesnt go up all the way, I'm scare it will brake. What do I do?
Old Jun 6, 2005
BassKadett's Avatar
Now I'm not 100% on this, but it seems like there are still some clips holding it down. I haven't ever taken the console apart, but everything else on the car is held on by clips so its the logical choice for me. Maybe try prying at the attached part a tad more.
Old Jun 10, 2005
Ok, I finally got to my deck but now I need to remove the CD mechanism out but I don't know how, I'm stupid. There's some screws in there that aren't magnetic and I'm afraid I'll lose them. Please tell me how. Here's what I got done so far.
ID:	55388   Click image for larger version
Old Jun 10, 2005
tinman's Avatar
OK, you have the newer deck. All you need to do is take out the 2 screws in the front of the mechanism and 2 in the rear. You'll see them on the bottom of the mechanism when you look from the top. 4 screws in all. Then the entire cd block just pops up. There is one connector on the right when viewed from the front. It's hidden underneath and holds on to the cd block. Just lift straight up.
Old Jun 12, 2005
Hey thanks, my cd player works now but the buttons are still sticky.
Old Jun 12, 2005
tinman's Avatar
Then take the face off and clean the buttons. Use some dishwashing detergent and water to disolve the sprite. Anyway, you learned something new.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
General DIY
Sep 25, 2015 08:02 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
jpat21
Sep 3, 2015 11:32 PM
