Made a few passes on my friends dyno today.
Old May 28, 2005
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
My friends bought a mobile dyno, started their own business a few months ago and have been taking it to events all over the area. Well today they set it up in a local parking lot and I decided to see what I was putting down.
First Run: 111.3 HP and 105.1 TQ in 3rd gear
Sec. Run: 107.2 HP and 104.2 TQ in 3rd gear
Last Run: 100.7 HP and 99.7 TQ in 4th gear
Was expecting a bit more. It was 80 degrees out though, high humidity, the sun was beaming down and we didn't let the car cool down that long(all 3 were done in a 10 min period). V2 intake was pretty hot. Hate that damn thing!!! As you can tell the numbers got lower, most likely because of this. 4th gear pull made peak power at 5500 rpm then fell out a bit. Don't know why? Need to get a wideband and see what's going on. Maybe SAFC or emanage and some tuning would help out.
I'll post sheets up later after they email them to me. The printed out one's didn't come out so great but I'll post em for now.
ID:	54711   Click image for larger version
Old May 28, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
I wonder if you had vtec if the numbers would have been any different.... Although I kinda doubt it..
Old May 28, 2005
VTECTypeR's Avatar
Thats pretty good for a lx motor
Old May 28, 2005
CivicsRdBest's Avatar
hmm... interesting numbers...
Old May 28, 2005
Redline04's Avatar
I was expecting 115. So I guess I was pretty close, but I'd like to do it again on a different dyno inside somewhere cooler(not in the hot *** sun) and maybe get a CAI. That 4th gear drop off sux too. Need to find out what's going on there.
Old May 28, 2005
not bad at all. Its not the intakes fault about getting hot. For you, I would think about getting a metal ebay intake heat shield for the filter and some thermotec intake wrap for the pipe. But at least get the heat shield. After I get the typhoon on with heat shield, I'll be doing another dyno soon.
Old May 28, 2005
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
110 Hp and you run 15.1 ......
Old May 29, 2005
Got Boost???'s Avatar
hes done alot of weight reduction^
Old May 29, 2005
Redline04's Avatar
That was back when temps were in the 50's. Probally would dyno a few extra ponies in cooler weather. The sun was beaming today(dynoed in the middle of a parking lot). Temps are now 80-90's with damn near 100% humidity. I ran a 15.3 two weeks ago on DR's(high 80's for temp) and last night I ran 15.7's all night on my new Azenis at a different track with a strong 10mph head wind. 2.2 60ft's on the azenis every run compared to the 2.0's I normally pull on DR's. So if I had ran DR's I would have probally ran a 15.4-15.5. 15.3 or better maybe without the wind?
So I would say I ran a 15.3 with 111hp. 15.1 with a few extra ponies. Also I trapped 90mph when it was cooler, now I'm only trapping 86-87. So higher temps def. have slowed me down which probally means I'm making less power. Soon it won't matter what temp it is out side cause my intake temp will be 10-20F . One more thing I was pretty happy with 105 ft/lbs of torque. Haven't seen any other NA D17's making over 100 with just bolt ons.
Old May 29, 2005
scansel912's Avatar
How'd you get so good of a 60 foot if the ambient temp was in the 50's. that would mean the track would be colder and harder to launch on unless you ran at night and the sun heated the track up earlier in the day.
Have fun with nitrous BTW. Don't suck at ur 60 foot like I did.
Old May 29, 2005
the temp has alot to do with numbers being low. Its kinda odd tho because I've seen stock ex dynos around 100-110whp. And your mods should have put you higher, even with lx.
Old May 29, 2005
Logan3024's Avatar
Gearbox youve been here for what.......4 years? You should know by now that intake and exhaust does not give 10+ whp.
Redline04
Was this dyno with powersteering and ac belts on?
Old May 29, 2005
tripledoublegs's Avatar
Euro-Spec
he doesn't have nitrous
Old May 29, 2005
scansel912's Avatar
He will shortly unless he has a freezer in his car connected to his intake.
Old May 29, 2005
he has alot more mods than just intake/exhaust.
Old May 29, 2005
Redline04's Avatar
It was on a sunny December day. Track was warm, air was cold. Perfect conditions.
Gearbox, I too thought I would put down a bit more. I guess it was the heat or maybe the dyno? There was an automatic CL Type-S that put down only 210whp with I/H/E. But then again don't most people Dyno 85-90whp stock on DX's and around 100whp with mods. What about the torque? 105 seems pretty good. You made around 90 right?
Dizzle this was with power steering belt off, ac is still hooked up. Was going to take it out but it's too fauking hot!!!
I don't have N20, but I'm gonna order that new NX wet kit very soon.
Old May 29, 2005
i still think its an accomplishment, cause obviously hp is only part of it. Just look at the great 1/4 times you're getting. Enough to beat the average civic around here at least.
Old May 29, 2005
Redline04's Avatar
Thanks for the props. Like you said I guess HP isn't everything.
Old May 29, 2005
Ashhole's Avatar
Ashho-san 7thgen Ninja
Ashhole will become famous soon enoughAshhole will become famous soon enough
i had similar results as your dyno at the track the other weekend. the more i ran, hte slower my times got. didnt really give the motor time to cool down.
Went from 15.9 all the way down to 16.7
Old May 29, 2005
Redline04's Avatar
Congrats on the 15.9
I still dynoed more than this EX with I/H/E.
http://www.hondatuningmagazine.com/tech/0203ht_nx/
I guess that's pretty good considering I started with 10whp less.
Old May 29, 2005
scansel912's Avatar
Is there a thread that explains in detail how to take the powersteering belt out. Is it alot of trouble or really easy?
Old Jun 1, 2005
allmotor's Avatar
nor cal 7thgens
good numbers redline. Now i wonder what times u will get with spray
juror
Suspension DIY
Jul 30, 2019 03:28 AM
cukaracha
Jul 17, 2015 05:48 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
