rsx injectors into fuel rail
Old May 25, 2005
drunkenmagnum's Avatar
how do i make rsx injectors fit into my fuel rail. i have been told they will fit with minor modification but no one seems to know how. if someone could PLEASE help me with this i would be very very thankfull!!
Old May 25, 2005
rep points to whomever helps me
Old May 26, 2005
18inchpride's Avatar
18inchpride is an unknown quantity at this point
have you checked the DIY dezod kit install, i believe those are the injectors used for the kit!
Old May 26, 2005
JesterMasque's Avatar
...ever grinning...
JesterMasque is an unknown quantity at this point
I'm interested in this too... Cause I see alot of people selling RSX injectors for cheap.
Old May 27, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
I just pulled out the stock injectors and put the Type S ones in. They fit fine. The only problem is that they are longer than our stock injectors so you have to take the studs out and replace them with longer bolts. They were really easy to install.
Old May 27, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
any idea what side bolts???
Old May 27, 2005
tfnaaf's Avatar
BLDNPSI Mod
Just guessing , prolly 8mm X 1.25 X ???? length, But they may be 6mm.... i havent installed mine yet so im not for certain atm! May want to use some sort of spacer between the rail and where it bolts down to make up for the extra length needed.
SimpleUser
Apr 24, 2021 02:54 AM
GritzNGravy
Aug 19, 2015 03:03 AM
RIPSAW
Aug 16, 2015 12:14 PM
martinsmartin
Aug 15, 2015 07:34 PM
Green02civic
Jul 27, 2015 10:48 PM
