tire pressure for 205/50R/15's?
Old May 23, 2005
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
what tire pressure would you recommend for street use for a 205/50R/15? and what pressure for auto-x?
Old May 23, 2005
Zzyzx's Avatar
Autocross Junky
street, Use stock PSI, 30F 30R. autocross, this is going to be a test n tune thing which depends greatly on your setup, such as alignment. but any way, before I got a camber kit, I ushually ran the fronts at around 45 and the rears at about 36-38..
Old May 23, 2005
Skunk2ner's Avatar
thanks for the info!
+rep
Old May 23, 2005
Zzyzx's Avatar
Autocross Junky
Just so you know, It also deals alot with what tire you are using, as each brand and make has different sidewall stiffness and will need different preasures to prevent/limit tire rollover.
Old May 23, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
it depends on the tire, it depends A LOT on your alignment.
I ran Kumho MXs about 41 front 45-47 rear
I run Falkens about 38 front 42 rear
More camber lets you run lower pressure. If you're running something stockish for an alignment you need to run more pressure.
I'm running -2.25 on the nose and -1.6 on the rear.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
cukaracha
Jul 23, 2015 08:50 AM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
