Shorter clutch pedal throw?
...ever grinning...
I miss the whole transmission/clutch feel of my 95 sooo bad... just about the only thing I miss about it. Is there a way to get a shorter pedal throw when i do my clutch? Also I'm running just a stock motor and I was wondering what the best would be? Many people tell me Exedy. Are the ones off eBay good or should I go elsewhere? But please give me a response about my pedal. Thanks!
Wanna see a donkey show?
Funny is my pedal feel is goin down too. I am not dropping the clutch or any thing. I just think that my 2002 ex has a weak clutch. I found a clutch setup for our year from a company called spec clutch. My buddy who has a custom hot rod shop here in sac said he runs them on mustangs infact he just built a super charged 5.0 and ran a stage 3 spec clutch it should be around 1000 hp when they customer gets the 25lbs of boost super charger. Any way he recommended I run a stage 2. They are 299 buks and you get all what you need and the stage 2 is made of kevlar! Here is the site http://www.specclutch.com/specMain.html, good luck.
I have a few bolt ons like full exhaust header aem v2 intake and larger wheels. He rec. that model and if you look it shows it has good holding power and has the strength to handle some thing like auto cross. Which is what I would like to do. Just to let you know I only have 30700 miles have never dropped the clutch off the line and have lightly power shifted second, nothing crazy and it is going. It still grabs good but the pedal feel is diff and the enguagement point is very shallow. So I think it is going but could last until I can afford to do it. My only worry is after a good clutch, is putting too much pressure on the tranny. But **** they are so cheap I might just buy one for a just in case!
I feel ya. You might want to run a dual centerforce or some thing cheaper. Getting it installed is the biatch. I was goin to do my own but i want a company to do it for the resale of my car. In 2 years might trade up to a new rsx. Ohh ya you can also look on summitracing.com and check them out they price parts really well and they have stuff for our cars!
2. Its pretty stupid to put on more than the lightest clutch that can hold the power you have for autocross. Its even stupider to put on anything more than a stock clutch because of the severe bump in classing that comes along with it. Most morons behind store counters don't even know what autocross is, let alone what it takes to run it. Even most people who roadrace will use a Honda clutch or an OE replacement clutch.
3. Stage97698235693486 clutches put more wear and tear on your driveline because they grab a heck of a lot harder, with stiffer hub springs or no springs at all, so there's less room for screwups and more shock loading directed to the transmission.
4. Its a hydrotranny, the travel won't change, the only thing you may be able to change is the location it engages.
...ever grinning...
Damn... I was hoping I wouldn't get that answer. But since I got practically stock I should just go with an OEM Honda or should I go with an aftermarket company for a stock replacement?
1. Bolt ons do not warrant anything more than a stock clutch.
One I am not going to listen to some *** tell me what i should not run. I have been working on cars since 10 years old. And have built many projects one of them being a ford truck with a 351w world heads 202 160's and a toploader 4spd. I went through 4 oem style hd truck clutches in a 1-2 year period. I had far too much tq. I finally blew the toploader and ran a tci small c-6 and blew that up 2 years later. All that was just bolt on heads and stock cam profile and 30 over. With maybe 9.5-1 comp. And no shat it puts more pressure on the tranny if you drive it right you can save it from going out. My pedal eng. point is now very shallow and not half as stiff as when I got it at 28745 miles. So in about 3k miles it has gone out, and you say run the same **** again, I do not think so a stage 2 spec is one under a clutch rated the ultimate street and strip and a tick over a oem style. Whats is wrong with that i mean did you even look at the site or get bitter and reply your great knowledge!
...ever grinning...
Wait... small question:
I test drove this 95 EX one time and all it had was bolt ons (i/h/e) and I remember the clutch travel was almost half and that's a pnumatic system too... How'd they do it but I can't?
Back From The Banned!
My brother has a 93, and his clutch point and clutch travel was altered.... but a mech did it for him.... mentioned some sort of screw at the very top parts of the clutch pedal. The 93's engagement point seems like just slightly over an inch.
...ever grinning...
Well, engagement is by adjusting the clutch when it's put in, right? That's what I always thought (with a hydro clutch anyway). But I want to know about travel, cause now I got two instances where the travel was altered.
<<<------ who has 51000 miles, 3 track days, 50+ autocrosses and 2 new stick shift drivers on the stock clutch and it never slips.
...ever grinning...
Yea, that seemed kinda odd to me too about all those problems. Cause I beat the HELL outta my stock and I got 58k and I trained like 4 people too. (I'm soo mean to my baby)
master of the culinary martial arts
If I remember correctly, Arospeed makes an adapter for the clutch pedal that shortens the throw in a fashion similar to how a short throw shift adapter for your shifter works.
Originally Posted by JesterMasque
Can you find it? And does anyone got any rebuttle to this about how it could damage anything possibly?
http://www.arospeed.com/default.php?cPath=22_124
I don't know if this will even work on civics or how you'd install it. You'd have to call and ask the company or find somebody who has one.
Well, I could tell you you need driving lessons. Thats probably the only way to kill a clutch in 3000 miles. Or you got a bubble in the clutch line and you need to bleed it out to get the feel back. Before you go running out shitting a brick about needing more holding power (stage 2 tends to be 80-120% over the capacity of stock, which translates to "If you're not running a turbo you don't need it"), maybe you ought to look at the system on the car and figure out if you got some sort of issue. 28000 miles out of 1, then 3000 out of another and I think anyone would agree you're doing something wrong.
But then that truck you have is not a civic. Stock is fine, stage 1 at most, and that is already over doing it. A stock clutch doesnt engage as harshly, so more of the wear and tear is put on your clutch instead of your transmission and other drivetrain parts. The higher that stage, the faster engagement meaning more wear on the transmission. I can't say much as i just had a stage 1 put in, feels stock, but those are the facts.
...ever grinning...
So not only should you have appropriate power for what clutch you use, but also a more HD trans as well... I know it's common sense, but most people only attribute which clutch with numbers only.
But is that the only thing that could possibly change my pedal travel is the Aerospeed piece? Anybody else got any other ideas?
mjdiaz89
Jun 21, 2016 09:26 PM
EM_WON
Jul 22, 2015 06:49 PM
Kyles24
Jul 12, 2015 09:15 PM
06Si_Girl
Jul 12, 2015 12:08 PM
