neuspeed rear sway bar
Old May 8, 2005
03CivicEX4Door's Avatar
03CivicEX4Door is an unknown quantity at this point
I want to get a neuspeed rear sway bar, can any 1 tell me if it will work with ther rear lower strut brace ?
Old May 8, 2005
robbclark1's Avatar
Retired suspension supermod.
What is a rear lower strut brace? You mean a rear lower tie bar? No, the Neuspeed bar has an integrated tie bar. Get the comptech bar if you alread have a rear tie bar. It is 22mm and you can get one from ebay for like $100 shipped.
Old May 8, 2005
this is what i have http://www.neuspeed.com/products/product_details.asp?app=48|CV&type=12&ltype=ns_imp ort&p_id=1038
Old May 8, 2005
robbclark1's Avatar
You can do one of a few things
1) buy and sell your neuspeed tie bar because as you can see the neuspeed sway bar has an integrated tie bar
2) Buy an ITR or comptech 22mm sway bar and keep your neuspeed tie bar and have the same performance for half the price.
I can't see paying that type of money for a 22mm sway bar when you can get cheaper ones and use the tie bar you have.
Old May 8, 2005
where the sway bar bolts up to the tie bars is totally different from where the plain tie bar bolts up. I don't see why both could not be used together. But i do understand what you're saying.
Old May 8, 2005
Old May 8, 2005
robbclark1's Avatar
I can't find a damn pic of the neuspeed installed but here is the progress bar. See how the integrated tie bar dips down to help brace the frame. You can't use both. If you really want the sway then sell the tie bar you have now.
Old May 8, 2005
i guess i'll sell it. Cause i want the neuspeed sway bar. Will a new front and rear make any difference for stock sway bar's
Old May 8, 2005
robbclark1's Avatar
yes. They will make a big difference. What year civic do you have? What are you goals for the car?
Old May 9, 2005
2003 civic ex sedan. Finish extiriour, suspension for right now.
Old May 9, 2005
robbclark1's Avatar
But what do you want to do with the suspension? Are you racing? The roll bars will make a big difference. My friend has the progress kit and it is nice.
Old May 9, 2005
no i'm not racing. Get these sway bars and coilovers then that will be it.
Old May 9, 2005
Does Neuspeed make a front sway bar for my car.
Old May 9, 2005
robbclark1's Avatar
apparently not.
Old May 9, 2005
you're right i thought the did cause i looked on ultrarev.com and it says 2001 - up (encluding si) But then you click on info and it says does not fit 2001 - up honda civic coupe - sedan, neuspeed sell's a bushing kit for my factory front sway bar.
Should i replace the factory front sway bar or just get the neuspeed bushing kit.
Old May 10, 2005
robbclark1's Avatar
If you are putting on the 22mm rear sway then your puny 15.9mm front sway is going to cause some oversteer. If you want a balanced car then I would suggest swapping the front too. You can get an 01-02 25.4mm one or progress 27mm one.
Old May 17, 2005
i just posted a new post in suspension performance having trouble installing rear sway bar take a look need help.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Marco83
Oct 13, 2018 10:13 PM
GotSiR
Jun 23, 2016 04:06 PM
muniorbust
33
Aug 31, 2015 08:59 PM
