FINALLY Finished My OEM Style Foglight Install
Well after making a new harness due to the crappy/incorrect one shipped with my oem style fogs, I finally got them put in and all wired up today!
Wasn't too bad once I got the wires where I wanted them.. And did anyone else notice that you don't have to use the grommet under the glove compartment if you follow the Honda Factory directions? There's a set of grommet type dealys on the inside quarter panel area that leads right inside with no cutting or anything, pretty sweet. So I made the new harness with 12ga. wire hooked up to a 4 pin relay and used the parking lights as the relay switch.. pretty basic stuff I guess. Then ran a new switch inside next to the cruise control (a non-OEM rocker swithc, but it does it's purpose).. I must say I'm pretty happy though. Just thought I'd share.
Wasn't too bad once I got the wires where I wanted them.. And did anyone else notice that you don't have to use the grommet under the glove compartment if you follow the Honda Factory directions? There's a set of grommet type dealys on the inside quarter panel area that leads right inside with no cutting or anything, pretty sweet. So I made the new harness with 12ga. wire hooked up to a 4 pin relay and used the parking lights as the relay switch.. pretty basic stuff I guess. Then ran a new switch inside next to the cruise control (a non-OEM rocker swithc, but it does it's purpose).. I must say I'm pretty happy though. Just thought I'd share. Joined: Sep 2003
i bought my fogs from procarparts.com, the ebay seller, not the website. it was a DEPO brand fog light, but it works perfectly! and the lense has not yet cracked.
anywho, slowvr4, looks great! i applaud your work
That's a huge compilment from such a lighting god as yourself! Much appreciated! And in case anyone lives in Upstate, NY; it's going to rain soon as I spent an hour or so washing/waxing my car today.
Touge
Jun 18, 2015 11:49 PM
Touge
Ottawa
Jun 5, 2015 11:15 PM
Touge
May 20, 2015 10:54 PM
Touge
Ottawa
May 20, 2015 10:53 PM
Touge
Apr 26, 2015 11:59 PM
